Last updated by Andreas W. 2 years ago.
May 2, 2024 at 3:04 pm #15588213
zia001
perfect. that worked! last question. please see attached image. i could not translate those using either glosssary translation and also string translation. these are blocks within the theme. i also tried to translate them directly in elementor but the translation applies to both english and translated language. please advise how to deal with this.
May 2, 2024 at 3:09 pm #15588252
Please provide me with more details about how this content was created.
It depends if you are maybe using a template that is created on the backend. In this case, you would need to translate the template with the WPML Translation Editor.
Are you maybe using an Elementor Template here? If so, please translate the template with the WPML Translation Editor to 100%.
Guide: https://wpml.org/documentation/plugins-compatibility/elementor/#translating-elementor-templates
If the strings of those widgets are part of a template but will not show up inside the WPML Translation Editor, then these Custom Elementor Widgets need a proper XML Configuration:
Otherwise, if we are not handling any template or Elementor Custom Widgets here, then you should use WPML > String Translation by following this guide:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
The topic ‘[Closed] Split: Issue to translate theme blocks’ is closed to new replies.
