Supporter timezone: Europe/Vienna (GMT+01:00)
Last updated by Lucas Vidal de Andrade 1 month, 3 weeks ago.
January 16, 2026 at 1:26 pm #17737118
niamhO
Hi Lucas,
Thank you for your help on this.
I have tested the site an processed all translation fully.
However, one item remains unchanged and that is the linking from the Family Room button - it reverts to the Triple Suite on all translations.
Please see attached screenshot of the location of the button on the French translation, as an example. The issue is consistent over all translations, while the English version links correctly.
Please also note:
- In some translations the button url does not seen to be coming in left at all (e.g. Dutch)
- In other translations (e.g. French) the button url is on the left, but it does not automatically populate to the right hand side. Please note the translation is marked as 100% complete. If I enter the button url manually and the 'Save & Continue' it opens to the Triple Suite page (I have left the link manually entered for you to test this).
If you could look into this issue, at your earliest convenience, I would appreciate it greatly.
Best Wishes
Niamh
January 16, 2026 at 1:34 pm #17737141
WPML Supporter since 11/2023
Hello there,
I've noticed that the translations of the linked pages have the "draft" status. Please ensure to have a backup, and:
1. Change the status of the translations (Family Room, Triple Suite, Double Room, Twin Room, and Single Room) to Published. You can do that by directly editing this on the page editor for the translated pages;
2. Make a small change on the home page in the default language and save. You can make a small edit on a text and save it, for example;
3. Open and re-save the translations. It's not necessary to make any changes; WPML should update the translated links automatically;
Let me know if that solves it.
January 16, 2026 at 4:07 pm #17737758
niamhO
Just to clarify Lucas, does 'Save and Complete' publish the translation?
January 19, 2026 at 8:31 am #17741319
Hello there,
No, it just saves the translation inside ATE. To publish them, you must find the translated page in the admin panel, and change its status to Published.
Let me know.
The topic ‘[Closed] Split: Links incorrectly translated’ is closed to new replies.
