Last updated by Dražen 6 months ago.
Assisted by: Dražen.
November 10, 2025 at 10:27 am #17561479
omer-duranY
Hello again. Yes, although some parts of the page were translated, the text inside the input boxes and the content of our fixed menu did not change. Only a few texts were translated. Could you help with this? This issue exists in both Spanish and English. The lower sections of the page, the top menu, and various page contents are populated with incomplete translations.Additionally, since the content inside the boxes is not being detected, I’m unable to edit it manually.
November 10, 2025 at 10:35 am #17561550
Dražen
I have checked and for menu you need to translate them first from Appearance > Menus:
Related documentation:
- https://wpml.org/documentation/getting-started-guide/translating-menus/#:~:text=block%20and%20menu-,Translating%20Menus%20with%20Custom%20Links,-Menus%20with%20custom
For other sections, I have added new XML code as they were missing. Please check.
Drazen
November 10, 2025 at 11:19 am #17561929
omer-duranY
Hello again. I found the navigation menu and translated it, but it still didn’t work. I can handle the menu part with the information you provided, but could you translate the lower section for me? I’d like to have it in both English and Spanish, please.
November 10, 2025 at 12:04 pm #17562198
Dražen
thanks for getting back.
1) I see your main menu is not translated still, you need to click + icon and create same menus for other languages. Image attached.
2) I do not understand what do you mean by "lower sections", can you please explain? Sections you reported before I have already added correct XML and on save automatic translation translated it.
Drazen
November 10, 2025 at 3:59 pm #17563314
omer-duranY
Hello, there is no problem with the menu, I can handle it. When I say bottom section, I mean the bottom of the site, here is the picture.
November 11, 2025 at 5:28 am #17564666
omer-duranY
Again hello my web site domain transfer... kolaykur.co transfer to easysetup.co
November 11, 2025 at 6:49 am #17564730
Dražen
1) Can you explain how this bottom section is built and where can I edit it?
2) As for domain, now when logged-in I can see what do you mean, but I am afraid this is not something caused or related to WPML. If you disable WPML issue is still there, and WPML does not cause make changes to your website domain. Most likely, it is related to your hosting or Hostinger plugin etc.
Please contact hosting support for them to check further and fix the issue.
Drazen
November 11, 2025 at 8:09 am #17565029
omer-duranY
Hello, I transferred the domain name myself, so that’s not an issue. The only problem is the translation of the bottom part of the website.
November 11, 2025 at 8:38 am #17565170
Dražen
I understand, but I do not see your website, it give blank WordPress page, so not sure where or how to check your website?
Please also share information needed from my previous reply (step 2) and I will be glad to help.
Drazen
The topic ‘[Closed] Split: menu and boxes not translated’ is closed to new replies.
