Last updated by Lucas Vidal de Andrade 1 week ago.
July 1, 2025 at 7:00 pm #17189938
abdullahA-127
i have found a solution to the issue, i just bulk uploaded the products image url again for the arab products and it is fixed now.
We can move to the next issue in which product bundles shows in english but when i change the language to arabic, the bundle shows no product.
english link - hidden link
arabic link - hidden link
kindly check it out please.
This is the last issue for this site.
July 1, 2025 at 7:02 pm #17189968
WPML Supporter since 11/2023
Hello there,
I've noticed that if you manually update the original product and save, the translation gets updated, and the issue is solved — bundle shows on translation. I couldn't figure a way to do that in bulk, unfortunately.
Please send me the Google Drive link with the backup found on All In One WP Migration > Backups, as I've requested previously. This way I can investigate the issue better.
July 1, 2025 at 8:02 pm #17190124
abdullahA-127
hi, if we can do it manually, that too is fine by me, I can do it one by one.
I tried to do for one product manually, but it didn't work out.
Can you please inform me what you did to enforce the change.
The product i tried - hidden link
July 2, 2025 at 8:57 pm #17194839
I checked again, and the solution didn't seem to work. I've escalated your ticket internally and will get back to you as soon as I have feedback. Thank you for your patience.
July 7, 2025 at 10:41 pm #17211338
abdullahA-127
Hi Lucas. Any update on the issue please.
July 8, 2025 at 4:36 pm #17215487
Hey there,
We still haven't figured out a solution, but we are analyzing it internally. I'll get back to you as soon as I have new information, ok? Thank you for your patience.
July 9, 2025 at 5:47 pm #17220634
Hello there,
We were able to find a solution. Please make a full website backup and follow these steps:
1. Go to Plugins > Plugin File Editor
2. Select WooCommerce Multilingual and Multicurrency and go to the file /compatibility/WcProductBundles/class-wcml-product-bundles.php
3. Find the code:
					if ( ! $translated_item_id ) {
						$menu_order = $this->wpdb->get_var(
							$this->wpdb->prepare(
                            SELECT menu_order FROM {$this->wpdb->prefix}woocommerce_bundled_items
	                        WHERE bundle_id=%d AND product_id=%d
								$bundle_id,
								$product_id
						$this->wpdb->insert(
							$this->wpdb->prefix . 'woocommerce_bundled_items',
								'product_id' => $translated_product_id,
								'bundle_id'  => $translated_bundle_id,
								'menu_order' => $menu_order,
						$translated_item_id = $this->wpdb->insert_id;
						$this->set_translated_item_id_relationship( $item_id, $translated_item_id, $lang );
and ADD this below:
					$check = $this->wpdb->get_var(
							"SELECT bundled_item_id FROM {$this->wpdb->prefix}woocommerce_bundled_items
             WHERE bundled_item_id = %d AND bundle_id = %d",
					if ( !$check ) {
								$bundle_id,
								$product_id
								'bundled_item_id' => $translated_item_id,
After that, you can go to the Products tab, filter the Bundles and Bulk update them without making any changes. That should solve the issue.
