Last updated by Andreas W. 1 year, 11 months ago.
August 24, 2023 at 5:39 am #14281541
mahmoudA-39
Hi
1- The second issue came up as a result of resolving main issue that site is slow. However , splitting the issues is fine.
2- Strings are in Vikbooking plugin. please see screenshots .
3- "Rooms" in Home page, search form , see screenshot
4- "string": Go to Home , click BOOK NOW without selecting dates. see screenshot
Slow site
Before testing the recommended solutions in the article:
1- How can reduce the 7000 strings?
2- I have removed many plugins. How can delete all their strings permanently?
Regards
August 24, 2023 at 4:03 pm #14287265
I see that the string "Please select Check-in and Check-out Dates and select the number of people per Chalet" inside the Pop-Up actually shows up as translated if I enable the option WPML > Strings Translation > Look for strings while pages are rendered.
I tried registering the string again but did not find a workaround for this problem in this case.
As this is a kind of complicated corner case, as WPML by default does not support editing original strings, I would suggest you keep using LocoTranslate for this task.
I hope for your understanding.
August 24, 2023 at 4:35 pm #14287337
mahmoudA-39
thanks. will keep Loco plugin
