The client reported an issue where footer widgets translated using string translation were still appearing in English on the frontend when French was active.
We recommended creating separate widgets for each language to ensure that the translations display correctly on the frontend. This approach can be more reliable than using string translation alone for widgets. For detailed steps on how to set up different widgets for different languages, please visit Translating Widgets.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket or visit our support forum.
Last updated by Ilyes 1 year, 3 months ago.
Assisted by: Ilyes.
June 6, 2024 at 8:48 pm #15713295
yuriiK-7
Similar issue with the footer widgets - I have translated them in the string translation, but they appears in the original English language on the frontend when French is active.
Please help
June 6, 2024 at 8:56 pm #15713329
Ilyes
Timezone: Pacific/Easter (GMT-05:00)
Hello again,
It seems this content is coming from a footer widget under Appearance > Widgets.
There is a better way to translate these widgets, by created one widget for each language like this : https://wpml.org/documentation/getting-started-guide/translating-widgets/#using-different-widgets-for-different-languages
I hope answers your question, let me know if you need help with it,
Best,
June 10, 2024 at 7:26 am #15720385
yuriiK-7
Hello!
All texts are now translated. I didn't use separate widgets for the footer. Just string translation.
For some reason after translation texts in the backend - it took some random time to update on the front end without any additional actions.
Maybe it is because of weak webhosting.
It is pretty strange, but it is resolved.
Thank you very much!
