Supporter timezone: Europe/Vienna (GMT+01:00)
Last updated by Jeff Boulton 4 months, 3 weeks ago.
October 9, 2025 at 12:13 pm #17471234
Jeff Boulton
Hello Lucas,
1. I've added the 'Exhibition' string to the theme’s sidebar.php file and translated it into Armenian, but on the Armenian version of the site, it still appears in English. Please see the attached screenshots.
String Translation page:
Front page:
2. I've installed and configured the GiveWP plugin in your sandbox account. With the default languages set to English and German (as the secondary language), everything works correctly.
After that, I changed the default language to German — it still worked correctly.
Then I added Armenian to the language list, translated the strings, and reproduced the issue.
Thanks in advance.
October 9, 2025 at 12:39 pm #17471358
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Hey there,
Regarding the strings from your theme, I created a new testing website. Please access it and install your theme there. Don't take any other actions. I'll setup WPML myself and make the necessary tests. Thanks in advance for your cooperation.
October 10, 2025 at 11:31 am #17474290
Jeff Boulton
Hello Lucas,
I've installed our theme on the sandbox website. The texts in it are in Armenian.
Please note that our theme is still under development.
Here you can see the added string in English that we’re unable to translate.
Theme path: themes/communityngo/patterns/sidebar.php
Thanks in advance.
October 10, 2025 at 1:40 pm #17474660
Thank you for sharing. I understand you refer to the “Exhibition” string. I checked the code and noticed they're wrapped in esc_html_e(), which won't work with WPML. Hard-coded strings need to be wrapped in __() or _e().
Please check our documentation for developers, review your code and ensure that it matches WPML requirements for compatibility:
https://wpml.org/documentation/support/achieving-wpml-compatibility-for-your-themes-and-plugins/
The creation and maintenance of custom code is outside the scope of this support, but the documentation is enough for you to ensure that the content from the theme is translatable.
October 13, 2025 at 11:04 am #17479266
Jeff Boulton
Thank you, Lucas!
We still have the same issue on our website, even when using _e().
I need to make some changes to understand the cause of the issue.
The topic ‘[Closed] Split: Untranslatable theme strings’ is closed to new replies.
