The client needed confirmation that WPML supports translations over API calls, specifically with custom languages, as this is a crucial feature for their blog.
We assured the client that WPML does indeed work with translations over API calls and that custom languages function with the same parameters as predefined ones. The only difference is that predefined languages are already set up within WPML. If you're experiencing issues with WPML's API integration or custom languages, we recommend checking that you have the latest versions of WPML, themes, and plugins installed. For further assistance, please feel free to open a new support ticket. We also highly recommend visiting the WPML known issues page to verify if there's a permanent fix for your issue and to ensure you're using the correct version of the fix.
If the solution provided here is not relevant to your case, or if it's outdated, please open a new support ticket for personalized support. You can do so by visiting the WPML support forum.
This topic is split from https://wpml.org/forums/topic/custom-languages-vs-redirect/
Assisted by: Andrey.
