When using WPML with Elementor, after editing a translation in the Advanced Translation Editor (ATE) and refreshing the page in Safari, the changes are not consistently reflected. This issue occurs especially after clearing the Safari cache and refreshing the page multiple times.
Disabling "MemCached" on the server helps
If these steps do not resolve the issue or if the solution provided here is outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket here.
This topic is split from https://wpml.org/forums/topic/should-i-try-to-prevent-elementor-from-autosave-translated-posts/
Last updated by 10 months ago.
Assisted by: Osama Mersal.
