The client is unable to translate the string "YOUR SHOPPING CART IS EMPTY" on the cart page even after following the steps of updating the theme, installing necessary plugins, using Elementor to build the cart page, and attempting to translate the string via WPML's String Translation.
We discovered that the string in question is considered an admin string, which can be customized directly within the WordPress Customizer. Here are the steps to resolve the issue:
1. Navigate to the WordPress Customizer.
2. Go to WooCommerce > Cart page > Empty Cart.
3. Save or edit the text directly in this section.
4. After saving the changes, go to WPML > String Translation.
5. Translate the string as needed.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
Last updated by Dražen 2 months, 4 weeks ago.
Assisted by: Dražen.
April 7, 2025 at 12:56 pm #16904512
takiC-2
so login page is fixed for now , but in other places for ex cart page the string : "YOUR SHOPPING CART IS EMPTY" it does not get changed
April 7, 2025 at 1:01 pm #16904555
Dražen
I have set up test site to try and translate the same string, but when I set up XStore theme I can not get same cart page, so I suspect some additional steps are required. Which ca,n in the en,d help clear things and why the string is not translated.
Can you please go to the next test site: hidden link, and create same cart page and share the steps with me on what you did. Also, make sure to update the theme to the latest versions on test site / live website, as I see they have done some changes to translation bugs.
Let me know how it goes.
Drazen
April 7, 2025 at 2:54 pm #16905059
takiC-2
steps :
1 - updated the theme
2 - installed the xstore-core plugin
3 - installed elementor plugin
4 - installed PRO Elements plugin
3 - xstore builder > cart page builder > Go to builder ( using elementor )
4 - added new Element > the default xstore Cart Widget > publish
5 - WPML > String translation > search for : YOUR SHOPPING CART IS EMPTY > translate all result
final result :
same problem strings does not get translated
April 7, 2025 at 3:04 pm #16905110
takiC-2
UPDATE : so i forgot to translate the Cart page , so what did
WPML > Transaction Managment > select Cart page > auto translate
so i've translated the Cart page
researched for "YOUR SHOPPING CART IS EMPTY" in String Trnaslation
new domain appeared where string exists which is xstore-core domain ,
retranslated all the result
but still same issue translation does not get applied
April 8, 2025 at 6:41 am #16906898
Dražen
Thank you very much for taking the time to reproduce.
I have checked, and it seems like a bug, so I have escalated it to our compatibility team, they will check and get back. Note, it may take a day or two.
I will update you here when I have some news.
Drazen
April 8, 2025 at 11:47 am #16908905
takiC-2
okay i'm be waiting for any updates
April 9, 2025 at 6:13 am #16911436
Dražen
we checked you can customize this string in the Customizer. That makes it an admin string. Save it in the customizer and it will appear in String translation.
Go to Customizer > WooCommerce > Cart page > Empty Cart, save or edit the text.
Then go to WPML > String translation and translate.
Drazen
