Last updated by Dražen 1 year, 2 months ago.
Assisted by: Dražen.
January 29, 2024 at 9:52 pm #15240961 | |
alexandreD-58 |
I am trying to: I have had a call with Lauren Jeffcoat where we have realized together that any modification done in WordPress didn't seem to save properly ever since I have installed the WPML plugin. At least, if I go on an try to translate a post, page or any type of content, the spinner icon will be visible in the element list but it would spin forever until I end up refreshing the page. Link to a page where the issue can be seen: hidden link I expected to see: The gearlwheel icon showing up instantly, confirming that my modification took place as expected. Instead, I got: |
January 30, 2024 at 9:01 am #15242141 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, can you please explain if the issue is with saving the regular page or issue is with the translation/status of the translated page. For example,, when you save your regular page, you expect it to be translated automatically, but is it not and is stuck or? Thanks, |
February 1, 2024 at 1:02 am #15252532 | |
alexandreD-58 |
Well, it happens if, let's say, I try to modify a Post and hit "Update". The button will turn into the spinner but the page will load forever until I get a HTML 500 server error. The same goes for the pages that I try to translate manually using the WordPress Editor. If I go back to the pages/posts list as shown above, the spinner indicating that the page is currently translating won't stop spinning. I have been suggested to increase the WordPress Memory Limit, which I did, but it doesn't seem to have solved the issue. I have also tried turning off the CDN in my hoster service GoDaddy in order to see if the wp-config.php file had effectively been updated, but to no avail. |
February 1, 2024 at 1:08 am #15252534 | |
alexandreD-58 |
I just noticed that it in't occurring with pages or events. Only with Posts. Sorry about that I though the pages had the same problem. |
February 1, 2024 at 1:10 am #15252535 | |
alexandreD-58 |
Spinning forever |
February 1, 2024 at 1:25 am #15252585 | |
alexandreD-58 |
Ok sorry again. I just tried modifying the english version of the homepage and it doesn't work either : the wheel is spinning, spinning... |
February 1, 2024 at 7:19 am #15253010 | |
Dražen Supporter
Hello, thanks for getting back. 1) You are mentioning here 2 different issues: A) When saving/updating the WP post and server returns a 500 error B) When saving post and WPML icon is spinning Did I understand it correctly? If so we will need to open new ticket for your other issue, as we limit 1 issue per ticket, let me know please. 2) Are you using translate everything or translate some from WPML > Settings, if so you can not mix methods of manually translating via WPML editor and or WP editor. Let me know, please. Regards, |
February 2, 2024 at 1:56 am #15257303 | |
alexandreD-58 |
Hi again! Yes, you did understand correctly. So, you are saying I should open a new ticket for the A) 500 error, am I getting you right? As for your second question, I went to WPML > Settings and the current setting is set to Translate What You Choose. Is that what you meant? As for switching from WPML editor and or WP editor, what I was doing so far was clicking on the cog icon AND switching to WordPress Editor, yes. Could that be what is causing the issue? I just noticed that my posts are still spinning. |
February 2, 2024 at 7:12 am #15257975 | |
Dražen Supporter
Hello, thanks for getting back. A) I think this might not be related to wpml, please first check if it still happens when wpml is disabled. If so, contact hosting support otherwise let us know or open a new ticket for this. B) Yes, you shouldn't be doing that and mixing editors, if you are using wpml editor to translate then you should use that or otherwise you should disable it by clicking WordPress editor and continue to manually edit 2nd language page. If you are trying to use wpml editor, please try to go to WPML > Translation management and send 1-2 pages for translation to yourself. Then go to WPML > Translations > take and translate and let me know if that works. - https://wpml.org/documentation/translating-your-contents/ Regards, |
February 2, 2024 at 4:02 pm #15260175 | |
alexandreD-58 |
« If you are trying to use wpml editor, please try to go to WPML > Translation management and send 1-2 pages for translation to yourself. » Ok I will try that, but in the meantime can I « stop » the current translations still going on and try again using the right way to translate my posts? (let's say through the WPML Editor only) Otherwise, could it be possible to grant you with my WordPress site credentials so that you could log in and have a look for youself? The is no sensible data whatsoever on our site (no user account, etc.) si there is no security issue. |
February 3, 2024 at 12:10 am #15261506 | |
alexandreD-58 |
I went to WPML Translation Management and saw this for one of the post which is still "translating" : "Waiting for translator", what does that mean? In the meantime, in the Post section I got this : "Edit the Anglais Translation" while the spinner is still spinnig. |
February 5, 2024 at 7:45 am #15264387 | |
Dražen Supporter
Hello, that is okay status, it means that translation is in progress and waiting for a translator (you or another user) to translate it. You can take and translate it further and it should work fine. - https://wpml.org/documentation/translating-your-contents/ You can do that from Pages > All by clicking the arrow icon or from WPML > Translations. But since the job is already in WPML > Translations, can you please try taking it from there and translating and see if that helps? Thanks, |
February 8, 2024 at 2:16 am #15279466 | |
alexandreD-58 |
Hi! Ok so I went to WPML > Translations and saw the post that were still waiting for a translator. What I did is I stopped them, went back to WMPL > Translation Management and switched back to Automatic Translation. I then bulk started the translations. Since I am now using the automatic mode the posts should translate by themselves, right? How long is the process supposed to take? Because it's now been several minutes that I have launched the thing and it is still processing. New threads created by Dražen and linked to this one are listed below: |
February 8, 2024 at 8:09 am #15279960 | |
Dražen Supporter
Hello, great, and yes if you have canceled the jobs and then enabled automatic translation it should translate automatically in the background. If the number is not lowered after a few minutes and translation are not delivered it could be they are stuck and something is causing issue, we would need to check on this. We limit 1 issue per 1 ticket, to keep things clear and easy to follow. I have opened a new ticket for your new issue: - https://wpml.org/forums/topic/split-translation-stuck/ Since the original issue of this ticket is resolved I advise closing this one and continue our conversation in the new ticket. Regards, |
February 8, 2024 at 10:24 pm #15283681 | |
alexandreD-58 |
Perfect. I am hence closing this issue. |
