The client was trying to translate a string from the string translation text on their website but encountered an issue where the expected translation 'leggi di più' was not appearing, and instead, it showed 'Explore more'.
We suggested that the issue might be due to duplicates of the same string, where only one is the correct one that needs translation. We recommended the following steps:
1. Navigate to WPML > String Translation and locate the checkbox 'Look for strings while pages are rendered' at the bottom of the page. Enable this option, visit the page where the string appears, and then return to WPML > String Translation to search for the string again.
2. If the string is not found in WPML > String Translation, it might be registered as admin text. We provided instructions on how to find and translate admin text strings: https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
Please note that the solution provided might be outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If necessary, please open a new support ticket for further assistance.
Assisted by: Mihai Apetrei.
