The client was unable to limit the countries where the Stripe payment method could be accessed at checkout. After selecting the desired countries and hitting the SAVE button on the Stripe settings page, the changes were not being saved. Upon refreshing the page, the payment method was still available in all countries.
We acknowledged an existing issue with the Country Availability option when using Stripe with WooCommerce. We recommended the client to follow the documentation provided to apply the necessary code to address this issue. The documentation can be found here: https://wpml.org/errata/woocommerce-stripe-payment-gateway-country-availability-changes-are-not-saved/
Please note that the solution provided might be outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket with us.
Last updated by Long Nguyen 1 year, 4 months ago.
Assisted by: Long Nguyen.
March 22, 2024 at 1:26 pm #15440685
FortunyShop
I am trying to:
Limit the countries where the Stripe payment can be accessed at checkout.
Instead, I got:
When I hit the SAVE button in the settings page of Stripe after I've chosen the Countries where I want to offer this method of payment, I get a SETTINGS SAVED message that actually does not save the Countries selection, so if I refresh the page the payment is still available in ALL COUNTRIES.
There was another post about this but never clearly solved:
https://wordpress.org/support/topic/unable-to-save-country-specific-availability/#post-15838928
How do I limit Stripe to only some countries?
March 25, 2024 at 4:15 am #15444551
Long Nguyen
WPML Supporter since 02/2022
Hi Matteo,
Thank you for contacting WPML support, I’m happy to help you with this issue.
Currently, there is an issue with the option Country Availability when using Stripe. Please follow the documentation below to use the code for this option
March 28, 2024 at 8:40 am #15459341
FortunyShop
Problem solved for now, thanks!
