You are trying to sync products for translated product categories on your site, but when switching to German, the product categories show 0 products, even though they are linked to the Dutch categories.
First, ensure that you update the product translation after linking the products. Follow these steps:
1. Edit the original Dutch product that contains that category.
2. Make sure that the category is assigned.
3. Add a tiny change to the text product description (you can remove it later) and update the product. You should see that product translations are requiring an update.
4. Navigate to the translation using the translation editor and complete the translation.
5. The translated German product should have the identical product parameters as the original.
If this method does not resolve the issue, consider using the bulk editing option:
1. Go to Products → All Products.
2. Select multiple products simultaneously and choose Edit from the Bulk action drop-down.
3. Change the Comments drop-down to "Allow," update the products, and then change it back.
4. Change the language to German and attempt just to update those products in bulk mode.
If these solutions do not work or seem outdated, or if they do not apply to your case, we recommend opening a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at https://wpml.org/forums/.
This topic contains 10 replies, has 3 voices.
Last updated by Andrey 1 year, 2 months ago.
Assisted by: Andrey.
October 7, 2024 at 1:25 pm #16261560
franciscusR
I am trying to sync products for translated product categories on my site hidden link. We have linked products to new sub-subcategories in Dutch, and ensured that the German translations of the categories are linked to the original Dutch ones via the 'This is a translation of' drop down menu.
When switching to German, the product categories have 0 products, even though they are linked to the Dutch categories.
How can we make sure that the German version of the category shows the same products without having to add them manually?
October 8, 2024 at 12:18 pm #16265330
Dražen
Thanks for contacting us.
I have checked your website but I see fine products in DE category, can you please share more info how can we see the issue?
Please also note that you must translate your products for them to appear in translated categories.
Drazen
October 8, 2024 at 12:53 pm #16265462
franciscusR
Hi Drazen,
For example this category: hidden link
When you switch to German, no products are shown. The products that supposed to appear are definitely translated.
Hoping for a faster reply this time.
Best,
Freek
October 8, 2024 at 3:05 pm #16266131
Andrey
WPML Supporter since 06/2013
This is Andrey here. I will be further assisting you. I hope this is fine.
Have you tried to generate Product lookup tables in WooCommerce → Status → Tools?
Another option to check is to run option 'Sync products categories (display type, thumbnail):' in WooCommerce → WooCommerce Multilingual & Multicurrency → Status and click the Troubleshooting link.
Before proceeding with any updates, please remember to back up your database.
October 9, 2024 at 7:56 am #16268354
franciscusR
Didn't work. I am going to do this manually.
October 9, 2024 at 8:52 am #16268697
franciscusR
I really don't understand this. We have manually added the product sub-subcategory "Carolina Reaper" to some German products, but that has removed all product attributes for the related products in German. The product attributes remained active on the Dutch and English version, since we didn't do anything manually over there. How does this happen and how can I get them back?
I do have this German product category now: hidden link
I want to be able to manually assign a sub-subcategory to a product without deleting all it's attributes. I also have no idea how to bring the attributes back on the product level, since these can't be added because they are translations.
October 9, 2024 at 2:11 pm #16270911
Andrey
If none of the methods worked, you probably need to update the product translation after linking the products.
The steps are as follows:
1. You edit the original Dutch product that contains that category.
5. The translated German product should have the identical product parameters as the original. After all these steps, categories and other parameters, such as attributes, should have been synchronized.
As for the other question, I have created a new support ticket. I will reply here: https://wpml.org/forums/topic/split-that-has-removed-all-product-attributes-for-the-related-products-in-german/
October 10, 2024 at 7:21 am #16273069
franciscusR
Yes, this solution helped (also for bringing back the lost attributes, other topic). But I hope you understand that this is a super labour intensive way of synching categories for 200+ products. How is it not possible to purge these product categories to other languages at once?
October 10, 2024 at 9:24 am #16273780
Andrey
I understand your concern. We have already attempted various solutions before manually updating the products.
Another thing to consider is using the bulk editing option to update the products further; however, I cannot guarantee that it will be helpful.
Here are the steps to follow:
3. You can try changing the Comments drop-down to "Allow," updating the products, and then changing it back.
October 10, 2024 at 10:01 am #16273951
franciscusR
That doesn't seem to help. We will do it manually.
October 10, 2024 at 10:13 am #16274043
Andrey
I'm sorry to hear this. I'm afraid manually updating is the only option left.
