Last updated by Bobby 1 year, 9 months ago.
Assisted by: Bobby.
September 28, 2023 at 12:30 pm #14481659
mahmutD-2
Dear support, in Woomultistore settings, I enabled the option Sync by SKU,
The problem that i have three languages, and i need to sync all the languages for the products, and because that i enabled Sync by SKU, i can sync only one language, If i sync other languages, it will overwrite the synced one!
If i disabled Sync by SKU option, I can sync all the products, But only one language have SKU! the other languages will be without SKU..
The question, How can i sync all the products with all product languages and keep the SKU for all of them, Like the main store.
sub-site
I am using
woo multistore
and WPML WC Multistore
October 2, 2023 at 4:45 pm #14499465
Bobby
WPML Supporter since 04/2015
Please verify that you are using WooCommerce Multilingual and WPML String Transaltion.
The SKU field is copied between languages and you cannot translate it, but you need setup properly the plugins in order to make it work.
Since the SKU field is copied it would only be copied from the default language into the translations.
The topic ‘[Closed] Sync translated products with SKU’ is closed to new replies.
