You are experiencing issues with the currency converter on your WooCommerce site, where the currency symbol changes but the amount does not convert correctly for some products. This issue arises because the prices are stored in the wp_postmeta table using comma separators instead of decimal points, which prevents them from being recognized as numbers suitable for calculations.
To resolve this, you need to correct the format in which prices are stored:
1. For simple products, simply re-save each product. This action will update the price format in the wp_postmeta table to the correct decimal point format.
2. For variable products, re-saving the parent product alone will not suffice if the prices are not altered. You must change the price of each variation slightly to trigger the update in storage format.
We have created a video to guide you through these steps, which you can view here: Video Guide.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket with us for further assistance.
Last updated by davidT-70 1 year, 1 month ago.
February 18, 2025 at 12:48 pm #16718903
davidT-70
I am trying to update the product, clear the cache, change the template to the factory one, and disable plugins to resolve an issue with the currency converter. The issue can be seen on this page: hidden link.
The currency converter does not convert currency for some products, just the symbol change
February 18, 2025 at 1:12 pm #16719001
Christopher Amirian
WPML Supporter since 07/2020
Thank you for your time. I'd appreciate it if you could confirm if the issue is happening on price range (variable) products only, or even the simple products with specific prices have the same issue.
If so, I'd appreciate it if you could provide login to staging version of the website (not live website) so we can do some investigative work there to identify the problem cause.
You can set the next reply a private to provide the info.
Also it will help if you can provide 2-3 more products that do not work for testing.
February 19, 2025 at 1:52 pm #16724956
Christopher Amirian
Thank you. I set your previous reply private as you included login information there.
I tried to login but unfortunately the login info is not correct.
felhasználónévhez megadott jelszó nem megfelelő. Elfelejtett jelszó?
Please select the private message checkbox on the next reply and provide the login information there.
Thank you for the steps you have done so far by the way, we also need your permission to copy your website.
February 20, 2025 at 2:31 pm #16730251
Christopher Amirian
Thank you for the login info. I managed to login and checked the issue and there is a problem that you can test here:
If you go to the edit screen of the product and then click the Variations tab, and click on one of the variations you will see that the price item there is empty (check the screenshot)
That is like that for all other variation items.
So there is no price in Hungarian version in the first place for WPML to be able to do any sort of calculation for the converted currency.
Please test by adding prices for each variation in HUF and you save the product. Then make sure the translation is 100% complete for other languages and then the conversion should work.
February 21, 2025 at 10:17 am #16733017
davidT-70
I don't understand.
There is a regular price for each product, and a sale price is not necessary.
February 23, 2025 at 4:38 pm #16738309
Christopher Amirian
Thank you very much. You are correct the variations have the regular price.
Would you please test if the same thing happens on a minimal installation?
- Switch to the default theme such as "TwentyTwenty" by going to "WordPress Dashboard > Appearance > themes".
- Go to "WordPress Dashboard > Plugins" and deactivate all plugins except Wooocmmerce, Woocomemrce Multilingual, WPML Multilingual CMS, WPML String Translation
- Check if you can still recreate the issue.
- If not, re-activate your plugins one by one and check the issue each time to find out the plugin that causes the problem.
If the issue still happens, we will need your permission to copy your website ot our server for further investigation.
February 24, 2025 at 10:39 am #16740229
davidT-70
I've already tried this, you can check it out.
This product's price change is still not good: hidden link
February 24, 2025 at 3:39 pm #16741986
Christopher Amirian
Thank you. I asked for help from the second tier support and will get back to you as soon asI have an answer.
February 24, 2025 at 6:16 pm #16742633
davidT-70
Thank you!
February 25, 2025 at 1:47 pm #16746170
Christopher Amirian
Thank you for your patience. I have an answerr from the second tier support.
Checking on a vanilla test site I can confirm that if your WooCommerce settings are to use a , as the decimal separator WC stores the price in wp_postmeta with a . decimal point separator regardless (i.e. as something a computer recognises as a number so that calculations can be performed on it, e.g. adding a percent tax).
The , is only ever used for display purposes.
But on your site the prices are wrongly stored in the postmeta table using comma separators, so as far as a computer is concerned they are not numbers and they cannot be used in calculations (e.g. to another currency). This doesn't affect some products whose prices are whole numbers and which therefore do not use a decimal separator, and recalculating their price works.
I don't know how the you ended up with prices stored in wp_postmeta in the wrong format, I imagine you may have imported them? Or perhaps some other plugin is involved.
To fix the problem of converting the prices the original prices themselves need to be fixed.
For simple products it is enough to re-save them: how the price is stored in wp_postmeta will be updated to the correct format.
I found that this didn't work with variable product prices, it seems if the price isn't changed then re-saving the parent product doesn't update how the prices are stored, and it is necessary to make a change to the price to each variation.
I created a video explaining all the details:
February 26, 2025 at 8:55 am #16749748
davidT-70
Thank you very much for your help.
It's such a small thing that I didn't notice it.
