Last updated by Andreas W. 1 year, 9 months ago.
June 17, 2024 at 10:09 am #15743811
alexeyK-12
We have already told you about this problem before: https://wpml.org/forums/topic/the-gender-filter-does-not-work/ Regarding this issue, we spoke with WPLMS, and for them, it works through BuddyPress. BuddyPress stores the profile field values in tables. WPML stores the translated version of these values in a global string "file". WPML was never designed for filtering, and BuddyPress never anticipated that strings would need to be translated. Here is the response from WPLMS: "so our basic search goes like this --- $xprofile_query[] = array( 'field' => $filter['field_id'], 'value' => $filter['values'], 'compare' => 'IN', ); .... $args['xprofile_query'] = $xprofile_query; $args = apply_filters('vibebp_members_directory_args',$args); $run = bp_core_get_users($args); ---- now instead of values, we need to find the ID of the field value in the tables and use them. which would modify the default BP query as it only deals with field ID not their value ID. hidden link 3 fold changes, a. in the directory apis where we show filters we need to send ID values of the filter options. b. change the value to id in the directory script c. in the API we need to fix the BP query to include values from the selected filter options
June 19, 2024 at 5:52 am #15752826
alexeyK-12
Thank you, we are awaiting your assistance.
June 20, 2024 at 5:57 pm #15765925
This issue was escalated towards our development team.
We currently have the following workaround:
One the file wp-content\plugins\buddypress-multilingual\includes\class.xprofile.php
Change line 12 to:
const FIELD_TYPES_WITH_OPTIONS = [ 'radio', 'checkbox', 'selectbox', 'multiselectbox', 'gender', 'option' ];
On line 29 add:
add_action( 'bp_xprofile_admin_new_field_additional_settings_gender', array( $this, 'saved_field_action' ) );
On line 43 add:
add_filter( 'bp_get_the_profile_field_options_select_gender', array($this, 'translate_multiselect_option'), 0, 5 );
This will make the option value "Gender" translatable with String Translation.
The only side effect, is that it will register a new string anytime you edit the option, instead of overwriting the already registered string, which means you need to manually clean up old strings on WPML > String Translation.
I hope this helps. If not, let me know.
June 21, 2024 at 8:34 am #15772452
alexeyK-12
We inserted the code snippets, but it didn't help.
June 21, 2024 at 1:54 pm #15775811
Take note, that prior to my provided workaround, which recently was escalated internally, it was not possible to translate the Gender Option in BuddyPress with WPML.
These snippets should register the strings for your Gender Option on String Translation and you might need to translate them again.
Did you try this already?
June 26, 2024 at 10:27 am #15832574
alexeyK-12
We checked the translations, and there are no new untranslated segments.
June 26, 2024 at 5:59 pm #15836497
My apologies for the delay in answering, as I have been sick for a few days.
IMPORTANT
I may have to install a plugin called "All In One WP Migration" to make a copy of the website where I can investigate the issue further.
However, I would also be very grateful if you could provide a staging site or copy of the website from your server yourself for this purpose. This step would only be required if the issue is replicable on such a staging site.
If you have any questions about creating such a staging site, you can consult your hosting provider. Just take note that WPML should be registered on this site again.
If you are unable to provide such a copy of the site for testing, please let me know on this ticket.
Video:
July 1, 2024 at 5:56 am #15865575
alexeyK-12
The site we are working on is the test site: hidden link
***CREDENTIALS REMOVED***
July 1, 2024 at 6:04 am #15865607
alexeyK-12
Check that your private messaging button is not working.
July 1, 2024 at 7:43 am #15866267
My apologies, but we are not allowed to access any sites unless the private reply form is filled out.
You were not able to see the form, as you need to also mark the second checkbox!
The private reply form capability is now enabled again.
July 2, 2024 at 3:23 pm #15876549
Indeed, until now the Gender Profile field was not considered to be translatable and our developers are still working on implementing this feature into a future version of BuddyPress Multilingual.
I see you are using on the page "App" the shortcode [vibebp_profile].
I see that this appears to be a WPMLMS related shortcode. I suppose this might be coming from the VibeBP plugin.
In this case this might be a compatibility issue between WPLMS/VibeBP and WPML and we would need to try to recreate this issue on a new test site and take further steps from there.
I would need your cooperation on this matter, as WPMLMS is a Premium Theme and we do not have a commercial lincense for it available.
Further, as our compatilbity team stated here, the Theme is sold commercial as WPML compatible and the author handles the compatilbity for WPML in this case:
https://wpml.org/plugin/wplms-2/
We can offer to have a closer look into the issue, but the final fix will need to be done inside the theme/plugin code by the theme author.
Let me know if you could provide the latest version of the WPMLMS theme and its plugin "VibeBP" for testing and I will send you a link to a WPML test site.
July 15, 2024 at 7:48 am #15952654
alexeyK-12
Thank you for not closing the ticket. We have asked WPML for permission to provide the latest version of the WPMLMS theme and its "VibeBP" plugin for testing and are still awaiting a response.
July 16, 2024 at 7:02 am #15958422
I am sending you a link to a test site with WPML.
Once you have the latest version of the theme and its plugins available, please install them here and send me a comment on this ticket.
One-Click-Login:
This ticket will remain open for 14 days and closes automatically in case do not receive any further from you in this timeframe.
The topic ‘[Closed] The gender filter does not work’ is closed to new replies.
