Last updated by Prosenjit Barman 1 year, 11 months ago.
June 27, 2023 at 1:24 am #13898745
nickS-28
ticking box and duplicating never works, always resets
June 28, 2023 at 5:50 am #13906789
Prosenjit Barman
WPML Supporter since 03/2023
Hi There,
Unfortunately, the issue you're having while duplicating a post is not much clear to understand. Could you provide more information about the issue or perhaps share a video of the problem? I will check properly and let you know the next steps.
Looking forward to your response and appreciate your kind cooperation in this matter.
Best Regards,
Prosenjit
July 11, 2023 at 7:39 am #14010921
nickS-28
Do you see the arrow in the image?
July 11, 2023 at 5:53 pm #14017407
Prosenjit Barman
Hi There.
I can see what you’ve highlighted in the screenshot. The “Duplicate” option should copy all the contents from the default page to the Translated page. If it is not happening properly on your end, would you kindly open the page in the default language(Lafargue Pianos) and try from there? I can see that you're trying to duplicate the content of a translated page into another language which is not recommended.
Please let me know the update. If you need further assistance, I kindly request you to share more information so that I can comprehend the issue better and offer a precise solution for your problem.
Best Regards,
Prosenjit
The topic ‘[Closed] ticking box and duplicating never works, always resets’ is closed to new replies.
