You are trying to translate WooCommerce variable products, but images, variations, and some meta data are missing in the translated products.
If you're experiencing this issue, we recommend you try the following steps:
1. Navigate to WooCommerce > WooCommerce Multilingual > Attributes tab.
2. Select the attribute from which the variation was created.
3. Click the Synchronize attributes button at the bottom.
Next, go to WooCommerce > WooCommerce Multilingual > Settings tab, click on the Troubleshooting link (bottom right), and select:
- Sync products variations
- Fix translated variations relationships
Click Start to synchronize variations across languages.
If the issue persists, navigate to WPML > Support > Troubleshooting page and press:
- Clear the cache in WPML
- Synchronize posts taxonomies (select 'product' and 'Variation')
- Set language information
This solution might be irrelevant if it’s outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum.
0% of people find this useful.
Last updated by gabrielT-11 1 year, 4 months ago.
July 26, 2024 at 8:59 pm #16009796
gabrielT-11
I am trying to translate WooCommerce variable products on my site hidden link. Everything seems to be properly set.
The images, the variations, and some meta data are completely missing in the translated products.
How can I ensure that images, variations, and meta data are included in the translated WooCommerce variable products?
July 29, 2024 at 7:31 am #16014070
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
Thanks for contacting WPML Support. Sorry for the delay in responding due to the weekend.
I understand the issue you're having. When translating a product, the variations should also be translated and copied to the translation, ensuring they appear correctly.
If the translated product is not showing variations, please follow these steps:
1. Go to WooCommerce > WooCommerce Multilingual > Attributes tab.
3. Click the "Synchronize attributes" button at the bottom.
Next, go to WooCommerce > WooCommerce Multilingual > Settings tab > Troubleshooting link (bottom right) and select:
Click "Start" to synchronize variations across languages.
If the issue persists, go to WPML > Support > Troubleshooting page and press:
Please let me know if the steps above help in solving the issue with variation on the translated product. if you need further assistance, I will be happy to help.
Prosenjit
July 29, 2024 at 9:37 am #16014910
gabrielT-11
Helo Prosenjit,
Thank you for your extensive answer.
I manage to make everything working properly by resetting WPML. The only issue I am facing still, is that product variations have no images (this issue is still part of the main issue of this topic).
If I go to the main product and I manually click on "update", then the images are showing, but I have thousands of products.
Is there a way to make variation thumbnail show up when the product is translated/duplicated?
I followed your steps but unfortunately not all languages are having variation images. 1 language has it and the other one not.
July 29, 2024 at 11:24 am #16015531
gabrielT-11
Going back to my issues, in translate products I was missing:
- Product image
- Variation images
- Stock
On top of it, when i translate any product, the variation in the original product were disappearing.
How I fixed everything:
I stopped using WPML Advanced Translator. What I do now is, I duplicate the products to other languages, then I export them, translate them, and import them back.
Everything is just absolutely perfect now.
I spent days trying figuring out all these issues, and apparently they all came from the WPML Advanced Translator.
Thank you for your help.
July 29, 2024 at 11:40 am #16015715
gabrielT-11
Duplicate content and then translate it makes the whole process flawless. WPML Advanced Editor unfortunately won't work as expected.
