Last updated by Prosenjit Barman 1 year, 10 months ago.
October 7, 2023 at 9:34 am #14532317
Вадим Сигаев
We discovered a problem with the translated version of the site. All menus do not load on the main page. Pages that were previously translated/created in a second language do not load at all. Example of links for two language versions of the site:
Translated - hidden link
Original - hidden link
Unfortunately, it was not possible to trace the cause of this problem in time. This may have happened after the latest WPML plugin update.
WordPress - 6.3.1
Theme XStore - 9.1.11
WPML Multilingual CMS - 4.6.5
Version of the site with an external language - hidden link
Please help us solve the problem.
October 9, 2023 at 7:00 am #14536099
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
Thanks for contacting WPML Support. Sorry for the delay in responding due to the weekend.
I checked the Translated version of the site and understood the issue. Upon checking, I found that the following things have not been translated into the Ukrainian language yet.
- Комплекты сантехники (Page)
- Котлы (Product Category)
- Насосы (Product Category)
- Черная сантехника (Page)
To see those items in the Ukrainian version of the site, please translate them first. If you need help in translating product categories, please check this documentation: https://wpml.org/documentation/related-projects/woocommerce-multilingual/#taxonomies
I hope it will help. Feel free to let me know if you need any further assistance. I will be happy to help.
Prosenjit
October 9, 2023 at 7:05 am #14536207
Вадим Сигаев
I know that not all pages of the site are translated, but what worries me more is that the translated pages do not load. Let me repeat the example:
October 10, 2023 at 3:27 am #14543381
Prosenjit Barman
Hello There,
Thank you for sharing the links.
I checked again and noticed that the default archive template is still loading on the translated version of that page. Maybe the translation of that template is not fully completed yet which is why, the contents in the translated version are not showing correctly. Please try the following steps and check if that helps to solve the issue.
- Please clear the site's caches.
- Navigate to WPML > Support > Troubleshooting.
- In the "cleanup" section, choose "pages" from the dropdown and then click "Synchronize post taxonomies."
- Afterward, click the buttons marked in this screenshot: hidden link.
- Once done, open the main page and make a small change in the title
- Save the changes and update the translation. Make sure to 100% complete the translation.
Feel free to let me know if you need further assistance in this matter. I will be happy to help.
Prosenjit
October 10, 2023 at 6:57 am #14545069
Вадим Сигаев
Unfortunately, these steps did not fix the problem. In addition, last night WordPress sent an error with the WPML Multilingual CMS plugin:
An error with type E_ERROR occurred on line 36 of the file /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/records/class-wpml-tm-icl-translation-status. php. Error message: Uncaught InvalidArgumentException: Unknown column: rid or invalid id: 0 in /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/records/class-wpml- tm-icl-translation-status.php:36
Stack trace:
#0 [internal function]: WPML_TM_ICL_Translation_Status->__construct(Object(wpdb), Object(WPML_TM_Records), 0, 'rid')
#1 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/vendor/otgs/auryn/lib/Injector.php(415): ReflectionClass->newInstanceArgs(Array)
#2 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/vendor/otgs/auryn/lib/Injector.php(373): WPML\Auryn\Injector->provisionInstance ('WPML_TM_ICL_Tra...', 'wpml_tm_icl_tra...', Array)
#3 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/container/class-wpml-container.php(98): WPML\Auryn\Injector->make ('WPML_TM_ICL_Tra...', Array)
#4 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/container/functions.php(29): WPML\Container\Container::make('WPML_TM_ICL_Tra. ..', Array)
#5 [internal function]: WPML\Container\{closure}('WPML_TM_ICL_Tra...', Array)
#6 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/vendor/wpml/fp/core/functions.php(154): call_user_func_array(Object(Closure), Array )
#7 [internal function]: WPML\FP\{closure}('WPML_TM_ICL_Tra...', Array)
#8 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/container/functions.php(35): call_user_func_array(Object(Closure), Array)
#9 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/classes/records/class-wpml-tm-icl-translation-status.php(198): WPML\ Container\make('WPML_TM_ICL_Tra...', Array)
#10 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/inc/translation-jobs/helpers/wpml-update-translation-data-action.class.php(38 ): WPML_TM_ICL_Translation_Status::makeByRid(0)
#11 /var/www/sanhub/sanhub.com.ua/wp-content/plugins/sitepress-multilingual-cms/inc/actions/wpml-tm-action-he
I'm running out of time to complete the project, so I kindly ask you to help me as quickly as possible. If you need any additional information, tell me what it is, I will definitely send it to you.
October 10, 2023 at 7:03 am #14545415
Вадим Сигаев
I can’t understand why only the menu blocks do not load on the main page (see “false.jpg”). It should be like in the picture "true.jpg".
October 11, 2023 at 4:04 am #14554805
Prosenjit Barman
Hello There,
Thank you for trying out the suggestions.
Please be informed that we are allowed to handle one issue per ticket. As the issue that you mentioned in the last ticket is different than the issue reported initially, I kindly request you to create a new ticket for that. Our support team will be happy to check and assist you accordingly.
To solve the issue the primary issues, a closer inspection will be required to understand the root cause of the issue.
IMPORTANT
Best Regards,
Prosenjit
October 14, 2023 at 4:57 am #14576185
Prosenjit Barman
Hello There,
Thank you for sharing the login information.
I'm still investigating the issue you're having with the menu on the homepage in secondary language. Even after selecting the menu manually from the Xstore Header builder, the menu is not showing for some reason. It may take some more time but, as soon as I have any updates, I will surely inform you.
Thank you for your continued patience and kind cooperation in this matter.
Prosenjit
October 16, 2023 at 3:59 am #14581081
Prosenjit Barman
Hi There,
I hope you're doing well.
The configuration made for the Header seems to be correct but for some reason, it is not showing on the Ukranian version of the Homepage only. I also tried to replicate the issue in my development environment(Used the same version of the theme and core plugin) but everything works fine there. You can check from here: hidden link
I believe there might be a conflict between a theme or plugin that's affecting the menu functionality on your site. To diagnose this, I'd like to conduct a conflict test by temporarily disabling the theme and plugins. However, considering your site is live, may I have your permission to do the conflict test there?
If you want, you can create a staging site from the main site. This will allow me to conduct tests without impacting the main site in any way. I already have enabled the private box for you if you want to share access to the staging or testing site.
Looking forward to your response and appreciate your patience and cooperation in this matter.
Prosenjit
October 16, 2023 at 10:05 am #14583301
Вадим Сигаев
The site hidden link is a copy of the main site, so you can do everything you need there.
October 16, 2023 at 4:01 pm #14586733
Prosenjit Barman
Hello There,
Thank you for granting permission to conduct the conflict test.
During the investigation, I identified that the issue is coming from a plugin named "OnSale Page for WooCommerce". The menu started to show properly on the Ukranian homepage as soon as I deactivated the Plugin. Please check this video for a better understanding: hidden link
It appears that something within that plugin is causing interference with the Menu, especially on the Homepage, resulting in the problem. Since this plugin is relatively new and not listed in our compatible plugin directory, I kindly request you reach out to the Plugin Author/Support and discuss this matter. They can help you better in this matter.
I also have checked the Russian and Ukrainian versions of the "САНТЕХНИКА ДЛЯ КУХНИ" page and can confirm that the contents are showing perfectly in both languages.
Russian: hidden link
Ukranian: hidden link
Since everything works fine at the testing site, please check and confirm that the category is properly translated in the Main site.
Please let me know if there is anything else you need help with. I will be happy to assist.
Prosenjit
October 18, 2023 at 7:29 am #14599575
Вадим Сигаев
Thanks, this helped!
There are still questions, but they do not directly relate to the topic of this appeal. Is it better to create a new request or can we continue here?
October 19, 2023 at 2:55 am #14609667
Prosenjit Barman
Hello There,
You're welcome! I'm glad I could assist.
To maintain clarity and organization in each thread, we are allowed to address one issue per ticket. For that reason, I kindly request you create a new thread mentioning the other issue. We're here to help and will gladly assist you with it.
Thank you for understanding. Should you require any assistance or have any questions related to this particular thread, feel free to let me know. I will be happy to help. Otherwise, please mark this thread as resolved.
Best Regards,
Prosenjit 🙂
