The client is facing an issue where translated products on their WooCommerce site are recognized as unique products in HubSpot, rather than as a single product.
We explained that due to the design of WPML, each translated product, whether it's a product, post, page, or custom post type, has its own separate database entry. This results in multiple IDs and different URLs for each language version, which makes it impossible to link them as a single product in HubSpot.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we recommend opening a new support ticket. Additionally, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by Marcel 9 months ago.
Assisted by: Marcel.
September 30, 2024 at 11:20 am #16235788
Rob Coers
I am trying to ensure that translated products on my WooCommerce site are seen as a single product in HubSpot rather than as unique products. HubSpot Support has informed me that this issue originates from WooCommerce, and I should contact WooCommerce support for a solution. My site is hidden link, and the specific product URL in question is hidden link.
Full Hubspot message:
As I understand, when I click on the URL: hidden link the product is listed in 5 languages and you'd like to make sure it's linked as a single product rather than 5 different items into Hubspot, right?
If so, I've had a look into this and I'm afraid there isn't a way to do this in HubSpot - as the information is coming from the Woocommerce side.
I suggest you get in touch with their support and find out if there is a way to send the information as a single product than 5 others.
I understand this is not the answer you may have been hoping for, but I hope it clarifies what's possible for now within the tool.
Translated products are being listed as unique products in HubSpot.
Is there a way to ensure that translated products are seen as a single product in HubSpot rather than as unique products?
September 30, 2024 at 2:24 pm #16236756
Marcel
Unfortunately, this isn't possible due to how WPML is designed. Each product—whether it's a product, post, page, or custom post type—has its own separate database entry. As a result, you will always have multiple IDs and, consequently, different URLs.
Marcel
