Last updated by saeedG-2 1 year, 5 months ago.
November 26, 2024 at 6:05 am
saeedG-2
I am trying to translate some strings in a widget in my website footer at hidden link. I had a similar issue before, and Noman from support added some XML config codes to fix it. I changed the design and some widgets, so I removed the previous XML code. Now, I have the same problem with a new widget and tried writing the XML code myself, but it doesn't work.
Translated strings in a widget are not showing on the front end.
How can I fix the issue of translated strings not showing on the front end?
What XML configuration is needed for the new widget?
