The client was experiencing issues with WooCommerce products not displaying after translating them using WPML. The translated product pages were blank.
We identified that the problem was due to a string that had been translated with variables, which caused a fatal error in WordPress. To resolve this, we recommended the following steps:
1. Navigate to WPML > String Translation;
2. Search for the "You must be" string;
3. Edit its translation and remove the variables, ensuring the final result matches the provided screenshot.
After following these steps, the website should function correctly.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we encourage you to open a new support ticket. We also highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please contact us through the WPML support forum.
Last updated by Lucas Vidal de Andrade 1 year, 5 months ago.
February 23, 2024 at 12:44 pm #15337699
madH
I just recently bought your plugin and I am trying to make multilingual fashion store. But I am having issues with WPML when it comes to translating woocommerce products - they are not showing.
Here is a link of a product in English: hidden link
And this is the link of Serbian translation: hidden link
I tried to translate the page using WPML Translation editor and also WordPress editor and the page is just blank.
Can you help me to solve this issue? What did I do wrong?
Thank you in advance.
Sanja
February 23, 2024 at 6:41 pm #15339029
WPML Supporter since 11/2023
Hello and thank you for getting in touch with us.
Can you please share a screenshot of the page that is not working? Also, please share a screenshot of your “Products” page, in the WordPress admin panel.
This way I can better understand what's going on 🙂
February 23, 2024 at 9:24 pm #15339402
madH
Hello Lucas,
Sure. In the attachment you will find screenshots of the product in English (front end and back) which is working just fine. And screenshots of the same product in Serbian which is not visible.
I am also providing screenshots of the products in back admin and also WPML translation management, where you can see that this product is fully translated.
WPML works just fine on every other page and works well with WP Bakery also, so I dont understand why it is not working with woocommerce products.
I really need to solve this issue ASAP because we have to put shop online.
February 26, 2024 at 11:10 am #15343690
Thank you for sharing.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated.
IMPORTANT
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this:
February 26, 2024 at 8:44 pm #15346315
Hello Sanja,
Thank you for sharing 🙂 I've sent your ticket to our developers, to get a second opinion. They usually answer within 24 hours. I'll update you once I have feedback from them.
February 27, 2024 at 12:10 pm #15349001
madH
Hello Lucas,
Thank you for support. I hope the feedback will have positive outcome.
Sanja
February 27, 2024 at 2:43 pm #15349622
Hello Sanja,
We found out what was causing the issue. There was a string that was translated with variables, what was causing a fatal error in WP. Please follow these steps:
1. Go to WPML > String Translation;
3. Edit its translation and remove the variables. Your final result should be similar to the screenshot;
Now your website should work as expected 🙂
February 27, 2024 at 10:33 pm #15351529
madH
Hi Lucas,
This worked! Thank you very much. The website now works just fine.
This means that in the future, when there is variable in the english text (such as %s etc) I should not duplicate it in Serbian?
Thank you very much for you time.
Sanja
