You are trying to translate the 'Read More' text of the Read More block in WordPress Gutenberg using the Twenty Twenty Four theme. Despite following the provided documentation and adding translations to all the read more String Translations, the 'Read More' text is not translating on your home page in Spanish.
We manually translated the strings for you via the Gutenberg block editor. To see how we did this, you can refer to this screen recording: https://go.screenpal.com/watch/cZiVQmV8t26.
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at our support forum.
Last updated by Kor 1 year, 10 months ago.
June 21, 2024 at 11:59 am #15774551
rayaA
I am trying to translate the 'Read More' text of the Read More block in WordPress Gutenberg (using Twenty Twenty Four theme). I followed this https://wpml.org/forums/topic/i-need-help-with-the-system-text-laes-mere-read-more/ and added translations to all the read more String Translations.
The 'Read More' text is not translated on my home page in Spanish: hidden link
Why is the 'Read More' text not translating on my home page in Spanish despite following the provided documentation?
June 21, 2024 at 2:48 pm #15776286
Thanks for reaching us.
June 27, 2024 at 6:14 pm #15846012
Thanks for your patience.
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
June 27, 2024 at 6:32 pm #15846088
I've manually translated the strings for you via the Gutenberg block editor and could you please check and see if it's what you're looking for?
July 1, 2024 at 9:38 am #15867451
rayaA
Yes, thank you, this is what I was looking for. We will, however, add more translations to the website in the future so may you kindly explain how you manually added the translation please?
July 1, 2024 at 9:47 am #15867487
Thanks for your reply.
You can refer to this screen recording that shows you what I did to edit the template.
I hope it helps.
July 4, 2024 at 4:44 am #15888636
rayaA
Thank you!
