Last updated by Andreas W. 1 year, 9 months ago.
September 13, 2023 at 4:51 am #14386949
sudeepG-2
Actually, On my site some content is not changing in spanish even I tried all the solutions which you gave me through the support but it didn't worked.
Kindly share with me the proper solution about this so that my problem will be solve as soon as possible.
September 14, 2023 at 5:02 am #14393217
Could you please increase your WP Memory limit to 256M? 128M is the minimum required by WPML.
Your current values are:
PHP Memory Limit 512M
WP Memory Limit 40M
Add this code to your wp-config.php to increase WP memory:
Paste it just before:
/ That's all, stop editing! Happy blogging. /
Now, verify the current settings at WPML > Support > WordPress. Then complete the translation again.
These settings can be limited directly by your hosting provider, so I recommend you contact and ask them to modify them directly.
If you can get even higher values It would be great.
Note: WPML needs a minimum WP Memory limit of 128M to work only under a minimal environment, which means, with a default theme and no other plugins installed.
Now, try to apply the Spanish translation again.
If this will still not solve the issue, please let me know.
The topic ‘[Closed] Translation Help’ is closed to new replies.
