- | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | - |
- | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | - |
Last updated by Kor 1 day, 8 hours ago.
February 2, 2025 at 10:06 pm #16660695 | |
andreaB-8 |
February 2, 2025 at 10:08 pm #16660697 | |
andreaB-8 |
After automatic translation I see a lot of missed things Most important check Header here Another thing is check footer blocks in EN On footer of all pages are not translated. Thanks! |
February 3, 2025 at 10:23 pm #16664638 | |
andreaB-8 |
Hi, can you help me? |
February 4, 2025 at 6:40 am #16664973 | |
Kor Supporter
Languages: English (English ) Timezone: Asia/Singapore (GMT+08:00) |
Thanks for contacting us. This usually happens when WPML cannot recognize the strings from the header template. Please try searching for the String using the String Translations, as explained here, and see if it helps. https://wpml.org/documentation/getting-started-guide/string-translation/ |
February 4, 2025 at 8:34 am #16665257 | |
andreaB-8 |
Hi friend I tried but I can' resolve issue, can you try access on my site for verify? Thanks |
February 4, 2025 at 9:27 am #16665661 | |
Kor Supporter
Thanks for your reply. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified. Please note that it is important to have a backup for security purposes and to prevent any potential data loss. You can use the UpdraftPlus plugin (https://wordpress.org/plugins/updraftplus/) to fulfill your backup requirements. Your upcoming reply will be treated with confidentiality and will only be visible to you and me. ✙ To resolve the issue, I may need your consent to deactivate and reactivate plugins and the theme, as well as make configuration changes on the site if necessary. This emphasizes the significance of having a backup. |
February 4, 2025 at 2:16 pm #16667249 | |
Kor Supporter
Thanks for your reply. I've checked and I'm able to see the issue you had there. To fix this, I've enabled translations for your header and footer. Please complete the translations below and let me know if it fixes it. Header - hidden link |
February 4, 2025 at 2:35 pm #16667345 | |
andreaB-8 |
I translated... I think that I do right things... but I still see same issues hidden link |
February 4, 2025 at 2:43 pm #16667379 | |
andreaB-8 |
hidden link Even if I click on ACCETTA E TRADUCI and CONFIRM I still see same options. |
February 4, 2025 at 2:49 pm #16667435 | |
Kor Supporter
Thanks for your reply. I ran the footer translation twice and it worked fine now. Please make sure your Website meets the WPML requirements as listed here hidden link so that translations could run smoother. |
February 4, 2025 at 3:21 pm #16667617 | |
andreaB-8 |
Friend header is still missed, can you complete steps for me? Items are already translated needs only to CONFIRM page. Thanks! |
February 4, 2025 at 3:28 pm #16667634 | |
Kor Supporter
Thanks for your reply. I can see the Book Now button, as shown in the attached screenshot here hidden link . isn't this what you want? |
February 4, 2025 at 3:31 pm #16667657 | |
andreaB-8 |
Yes but header is still missed, check Italian version |
February 4, 2025 at 3:34 pm #16667695 | |
Kor Supporter
Thanks for your reply. I believe you're referring to the navigation menu items. That can be translated following the methods listed here https://wpml.org/documentation/getting-started-guide/translating-menus/ . Could you try? |
February 4, 2025 at 3:51 pm #16667752 | |
andreaB-8 |
(1) (2) and where you switch with tabs I see boxes in IT and not EN (3) (4) Thanks friend! |
