Supporter timezone: Europe/Madrid (GMT+02:00)
Last updated by Carlos Rojas 2 months, 2 weeks ago.
Assisted by: Carlos Rojas.
October 10, 2025 at 10:01 am #17474028
justinV-10
I am experiencing an issue with WPML and ACF on my site hidden link
. I am trying to ensure that when I clear an ACF field value in the source post, this change is properly reflected in the WPML translation. We are using the latest versions of WPML and ACF, and translating posts with custom fields generally works correctly. This same behavior has also been observed on two other client sites.
Screencast showcasing the problem: hidden link
When I clear a custom field value in the original post and update the translation, the field no longer appears in the WPML Translation Editor, and the previously translated value remains instead of being cleared.
Is it expected behavior that cleared fields in the source post do not update in the WPML translation?
How can we ensure that cleared fields in the source post are either automatically cleared in the translations or reappear in the Translation Editor for update?
October 10, 2025 at 11:53 am #17474391
Carlos Rojas
WPML Supporter since 03/2017
Please increase the WP memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
You can add this to wp-config.php to increase WP memory:`
/* Memory Limit */
You can double-check the WordPress memory limit in WPML -> Support
Once the WordPress memory limit is increased, double-check if the issue persists or disappears.
Carlos
October 10, 2025 at 12:19 pm #17474424
justinV-10
Hi Carlos,
Just to clarify: I had already increased the memory limit to 512 before, but the problem still persists. The ticket creation process asks for a debug log before suggesting to raise the memory, which might have caused some confusion.
October 10, 2025 at 12:47 pm #17474500
Carlos Rojas
Thank you very much for your clarification.
1.- Please share the access credentials to the site in your next message, which I have set private. This way, I will be able to reproduce the issue and double-check the configuration.
2.- Also, share a URL where the issue can be seen and we can use as a reference.
October 13, 2025 at 9:13 am #17478869
Carlos Rojas
Thank you for sharing the information requested
I would like to ask for your authorization to create a copy of the site to escalate this ticket to our 2nd tier of support, where our specialists will take a deeper look at this issue.
October 14, 2025 at 5:42 am #17481865
justinV-10
You have my authorization to create a copy of the site and proceed with escalating the ticket to your Tier 2 support team for further investigation.
Please let me know if you need anything else from my side.
October 14, 2025 at 11:41 am #17483482
Carlos Rojas
Thank you for your authorization.
I have escalated this ticket to our 2nd tier of support, where our specialists will take a deeper look at this issue and isolate its cause.
I will get back to you as soon as I get an answer from them.
Thank you very much for your patience and understanding!
October 27, 2025 at 6:46 am #17520090
justinV-10
Hey Carlos,
any news on this? 🙂
Greetings
October 27, 2025 at 10:19 am #17521146
Carlos Rojas
Hi there!
Our 2nd-tier specialists are still working on this issue, and they should have an answer soon. I will get back to you immediately after I get an update from them 🙂
October 29, 2025 at 3:20 pm #17530122
Carlos Rojas
The cause of the issue has been identified, and it has been escalated to our development team.
October 30, 2025 at 9:28 am #17531644
justinV-10
Hey Carlos,
Great to hear—looking forward to what they have to say.
Greetings
October 30, 2025 at 11:45 am #17532407
Carlos Rojas
November 10, 2025 at 12:03 pm #17562195
justinV-10
Hey Carlos,
have there been any developments?
Greetings
November 10, 2025 at 12:23 pm #17562271
Carlos Rojas
Our developers are still working on a solution. In the meantime, they found that if you add a space instead of deleting the value of the ACFs, it will be updated on the translations.
I will keep you updated.
January 12, 2026 at 7:57 am #17720198
justinV-10
Hey Carlos,
happy new year. Any news on this?
Greetings
