You are trying to manually translate WooCommerce products using WPML, but the translation options are missing in the product overview and individual product pages. You have confirmed that Product Translation is enabled in WPML settings, but you cannot update WPML plugins, and navigating to WooCommerce > WooCommerce Multilingual only shows the setup wizard.
First, ensure that the WooCommerce Multilingual plugin is installed and set up correctly, as this is necessary for translating products and their data. Complete the WooCommerce Multilingual setup by following the wizard. If the translation options are still missing after setup, try the following steps:
1. Clear the cache on your site and your browser.
2. Flush the permalink structure by navigating to Settings > Permalinks and saving the settings.
3. Check again if the translation options appear under "WooCommerce > WooCommerce Multilingual > Products".
If these steps do not resolve the issue, the problem might be outdated or not applicable to your specific case. We recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
