Last updated by Kor 1 year, 10 months ago.
June 10, 2024 at 5:20 pm
edoardod-8
I am trying to save the translation of a specific element but encountered an error. Here is the link to the screenshot: hidden link. The issue can be seen on this page: hidden link.
The original text contains nested formatting tags (one tag inside another). Please nest the formatting markers in your translation in the same order. It doesn't save the translation element.
Why is the translation of the specific element not being saved?
How can I resolve the error related to nested formatting tags?
June 10, 2024 at 6:11 pm #15723600
Thank you for your patience.
I've generated a new button on this page hidden link , as illustrated in the attached screenshot, and managed to translate it without encountering any problems. Please attempt to replicate the method I've described and confirm if it resolves the issue for you as well.
June 10, 2024 at 6:27 pm #15723641
edoardod-8
I want you to fix the above button that causing the problem of HTML Tag. It should not cause the problem when all the tags are placed but still it's not saving it.
Please don't give a generic solution, There are hundreds of pages, I cannot create duplicate buttons on all pages.
I want you to fix the problem of "element not saving because of tag"
June 10, 2024 at 7:13 pm #15723703
Thank you for responding.
I appreciate your understanding. I'll double-check and provide you with an update as soon as possible.
June 11, 2024 at 5:55 pm #15728555
edoardod-8
Any updates?
June 11, 2024 at 6:42 pm #15728735
Thanks for your patience.
I'm able to replicate the issue here hidden link on our sandbox site and this is the test page hidden link .
I will escalate this further to our 2nd Tier Support for further investigation and will get back to you once I've feedback.
June 12, 2024 at 7:03 pm #15733357
edoardod-8
Its been 2 days, any updates ?
June 12, 2024 at 7:10 pm #15733376
I've received a response from our 2nd Tier Support and this is what they mentioned.
Please use the workaround by changing the HTML code to the one below.
<em><u>hidden link</u></em>
To :
You can test it here hidden link
Using the login link here hidden link
A fix will be available soon.
June 13, 2024 at 1:29 pm #15736459
edoardod-8
My question's still there:
Why I cannot able to update translation with following code:
June 13, 2024 at 2:05 pm #15736670
The problem stems from the nbsp markers, which fail to save into xliffs, thus leading to issues with the Advanced Translation editors.
Our developers are already working on resolving this, and a fix will be provided shortly. In the meantime, please utilize the suggested workaround I provided earlier.
The topic ‘[Closed] Translation of specific element not saved because of HTML Tags’ is closed to new replies.
