Supporter timezone: Europe/Madrid (GMT+02:00)
This topic contains 13 replies, has 0 voices.
Last updated by iroM 2 days, 11 hours ago.
Assisted by: Paola Mendiburu.
July 22, 2025 at 11:25 am #17258975
iroM
I am trying to translate the products on our site using WPML. I have completed the translation 100% with no issues mentioned on the translation tool.
The translation remains in progress in the WPML Translations section, and the translated product has a different layout than the original.
Why does the translation remain in progress even after completion?
Why does the translated product have a different layout than the original?
July 23, 2025 at 9:37 am #17262974
Paola Mendiburu
WPML Supporter since 11/2020
Hi there!
This is Paola and I hope you are well!
If the translation remains in progress please do the following:
- go to WPML --> Translations Management and resend the product to translation
Please let me know if after this the problem is fixed.
July 23, 2025 at 9:57 am #17263030
iroM
I tried what you told me but the problem remains the same.
Also there is the issue I told you about the display of the translated products that have different layout for some reason than the products of the original language.
Do you maybe want me to share with you admin credentials so I can explain you better the issue and you can investigate on it?
July 23, 2025 at 10:44 am #17263361
Paola Mendiburu
Please let me know a product where I can see the issue.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Privacy and Security Policy
**IMPORTANT**
- Please make a backup of the site files and database before providing us access.
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box.
The private box looks like this: hidden link
July 23, 2025 at 11:15 am #17263562
Paola Mendiburu
Thank you for providing the credentials.
Unfortunately, I’m still unable to log in. When I enter the credentials, I’m redirected back to the login page. It seems the issue might be related to the CAPTCHA.
Additionally, I noticed that the website was blocked, but I have already unblocked it.
Could you please deactivate any firewall or security plugins and try sending it to translation again?
July 23, 2025 at 11:24 am #17263571
iroM
We don't use any security or firewall plugin that prevents the login.
Maybe you mean that it shows a warning that the access to the website is unsafe? That is due to we still have http connection not https. The site is not live. We will swap to https before we go live.
Depending on the browser you use, you can still bypass this warning and login normally.
July 23, 2025 at 11:56 am #17263717
Paola Mendiburu
I was able to login from Safari.
I see that when I send a page to translation the site gets blocked from our server.
In order to investigate the problem,as it is a development site, do you give me permission to deactivate plugins to see if there is any conflict with a plugin?
July 23, 2025 at 12:05 pm #17263739
iroM
Yes feel free to do that.
I also took backup in any case something goes wrong.
July 23, 2025 at 1:51 pm #17264220
Paola Mendiburu
The issue persists even with all plugins deactivated.
This indicates that your site is being blocked because it is not secure.
Could you please ensure the site is secured?
Once you’ve done that, let me know so I can check it again.
July 24, 2025 at 10:39 am #17266954
iroM
Hi again!
We added an SSL Certificate on the site.
Can you please check again?
July 24, 2025 at 2:21 pm #17267962
Paola Mendiburu
Hi!
Thanks for that.
I've just sent a page for translation, and it worked, the site didn’t get blocked.
Could you please give it a try as well?
July 25, 2025 at 8:37 am #17270338
iroM
I tried to translate a product, for example this hidden link . Although it seems it is translated, it still in remains in progress (see photo).
Also, what about the layout of the products? If you see this for example hidden link and the translation hidden link they have different layout. Why is this happening?
July 25, 2025 at 10:34 am #17270691
Paola Mendiburu
I was able to complete the translation but I see that the title doesn´t appear on translation.
Do you have a template for the product page? Pleasse let me know where I can find it.
I have also check and the theme options for each product are the same.
July 25, 2025 at 10:43 am #17270715
iroM
So the thing that the translation is mentioned that is in progress is not an issue? Because I remember that on all other sites I have been using WMPL when I completed a translation this section was shown as completed.
No, we don't use any template for the products. It's the default.
