The client is trying to translate the words 'SIMILAR POSTS' in a section added by the Kadence Carousel block but cannot find the widget in the string translation admin.
1. Navigate to WPML > Theme and Plugins Localization.
2. Select the Kadence theme and scan the theme for strings.
3. After the scan is complete, go to WPML > String Translation and search for the text.
4. If the text appears in the results, add the translation by clicking on the "+" icon.
5. You can also check in the Admin screen if that text is listed there. For more details, check the guide on translating admin and settings strings.
If this solution doesn't look relevant, please open a new support ticket.
Last updated by Prosenjit Barman 1 year, 11 months ago.
January 8, 2024 at 2:51 am #15158032
anneR-12
Tell us what you are trying to do? Translate the words SIMILAR POSTS
Is there any documentation that you are following? I tried to look for the widget in string translation admin but could not find it. Perhaps it is not a widget in Kadence?
What is the link to your site? hidden link
January 8, 2024 at 12:17 pm #15160225
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
I understand what you're looking for and will try my best to assist you in this matter.
While checking the "Similar posts" section, I noticed that the titles are being added by the Kadence Carousel block, which you are using to display the related posts. If the text is static (not added from the editor), then you should be able to find and translate the text from the string translation section. Could you please try the following and check if that helps?
- Please go to "WPML > Theme and Plugins Localization"
- Select the Kadence theme and scan the theme for strings
- Once the Scan is completed, please go to "WPML > String Translation" and search for the text.
- If that text appears in the result, add the translation by clicking on the "+" icon
- Additionally, you can also check in the Admin screen if that text is listed there. Check this guide for more details: https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#translate-admin-and-settings-strings
Please let me know if that helps or if you need further assistance in this matter. I will be happy to help.
Prosenjit
