You've manually translated a new page on your website from Croatian to English, but the translations remain stuck in the queue and do not appear on the live site. Additionally, the English version of the main menu doesn't show up.
First, ensure you are using the latest version of WPML. You can update WPML by visiting WPML update page.
If these steps do not resolve your issue, or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML Support Forum.
Last updated by draganaL-2 6 months ago.
Assisted by: Itamar.
October 12, 2025 at 5:57 pm #17477684
draganaL-2
I’ve recently created a new page on my website hidden link and translated it manually because I don’t have any translation credits left. My site’s default language is Croatian, and I’ve been translating it into English.
All my translations remain stuck in the queue. Even when I take the task, complete the translation, and confirm it, the translations still stay in the queue and do not appear on the live site. Additionally, the English version of the main menu doesn’t show up on the site.
Why are my translations stuck in the queue and not appearing on the live site?
Why is the English version of the main menu not showing up on the site?
October 12, 2025 at 8:01 pm #17477792
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
We have newer versions of our plugins than the ones currently on your site. If you don't see updates available for our plugins, please visit hidden link and click the 'Check for updates' button. Then please check if the problem persists.
If the issue persists and you require additional assistance, please share the access details to your site with me. I'm enabling a private message for the following reply.
Privacy and Security Policy
**IMPORTANT**
Itamar.
October 16, 2025 at 12:35 pm #17490322
draganaL-2
Hi, I have tried to do as you said but problem still stays. I will give you access to check what is going on.
October 16, 2025 at 12:39 pm #17490327
draganaL-2
How do i do that?
October 17, 2025 at 7:16 pm #17495136
Itamar
**IMPORTANT**
Itamar.
October 21, 2025 at 6:24 am #17501416
draganaL-2
Hi, can you tell me when can we expect solution? Thanks in advance.
October 21, 2025 at 6:56 am #17501484
Itamar
Please go to Plugins -> All Plugins, and see we have a newer version for WPML - version 4.8.3. Please see the attached screenshot. Please update WPML to this version and check if it resolves the problem. If the problem persits Please, try the troubleshooting section.
1. Take a backup of the DB of your site.
2. Go to WPML -> Support -> Troubleshooting (link)
3. Once on the troubleshooting screen, press the following buttons and check if it helps. Press each button at a time and wait for the process to complete.
- 'Synchronize posts taxonomies' for all the post types
- 'Clear the cache in WPML'
- 'Remove ghost entries from the translation tables'
- 'Fix element_type collation'
- 'Fix WPML tables collation'
- 'Synchronize local job ids with ATE jobs'
- 'Synchronize translators and translation managers with ATE'
- 'Set language information'
- 'Reset languages' Press this button only if you didn't add a custom language!
- 'Fix terms count'
- 'Fix post type assignment for translations'
- 'Cleanup and optimize string tables'
- 'Clear invalid strings'
*** Please make a backup of your database before using this.***
Itamar.
October 21, 2025 at 9:12 am #17502152
draganaL-2
Hi, as you can see I don't have that option (I am sending you screenshot). I have tried to update it with bulk actions and it still stays the same.
October 21, 2025 at 9:16 am #17502184
Itamar
Please go to hidden link and update WPML from there. Please see the attached screenshot.
Itamar.
October 21, 2025 at 10:11 am #17502466
draganaL-2
It worked when I updated it. Thanks.
