The client was experiencing an issue where translated articles were appearing in every domain's article flow instead of being restricted to their respective language domains.
First, we ensured that WPML was active and that the front page template code included the necessary adjustments. We added
'suppress_filters' => 'false'
to the query arguments to ensure that the filters are not suppressed, which is essential for WPML to filter content by language.
Next, we navigated to WPML-> Settings-> Post Type Translation section and set the posts to "Translatable - only show translated items". This ensures that only the posts translated into the current language are displayed on the site.
If you're experiencing a similar issue, we recommend you try the following steps:
1. Activate WPML if it's not already active.
2. Ensure that your front page template code does not suppress filters by adding
to your query arguments.
3. Go to WPML-> Settings-> Post Type Translation and set your posts to "Translatable - only show translated items".
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
This topic contains 27 replies, has 2 voices.
Last updated by Osama Mersal 1 year, 6 months ago.
Assisted by: Osama Mersal.
April 19, 2024 at 1:15 pm #15543830
zachariasD
When translating articles and posting them all translations appear in every domains article flow and not on each page, how do we set this up correctly? (original domain kimura.se)
April 21, 2024 at 11:54 am #15547109
Osama Mersal
WPML Supporter since 02/2020
1) First of all, sorry for the late reply; it was due to a higher workload. Please go to WPML-> Settings-> Post Type Translation, and set the posts to "Translatable - Show Only Translatable Items".
If that didn't help, please share screenshots or a screen-recorded video while reproducing the issue.
Osama
April 22, 2024 at 6:36 pm #15552672
zachariasD
Hello, thank you.
1) That setting is already in place.
2) Yes, sent the debug
As you can see in the images, when adding the translation from Swedish (original language) to English both articles appear in the flow on the Swedish version of the site.
All the Swedish articles are in the flow of the English version of the site aswell.
So all translations appear in all versions of the site for some reason 🙂
April 23, 2024 at 10:16 am #15554956
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
April 23, 2024 at 10:25 am #15555104
zachariasD
Sure, can we continue the conversation on email?
Ill try to recreate the issue on our staging site. I have one question though, since the live site is connected to the custom domains, should I do subdirectories for the translated sites on the staging site? Since both sites cant use the custom domain and we dont want to re-configurate the domain settings.
April 23, 2024 at 10:28 am #15555122
Osama Mersal
1) This is an email ticket, so you will get an email notification when we reply, but you need to reply here in the forum.
2) You can select subdirectories in the staging site.
Osama
April 24, 2024 at 6:15 pm #15562461
zachariasD
Okay,
Activate the private chat option again and Ill share the staging site info. I successfully replicated the issue 🙂
April 25, 2024 at 8:01 am #15563811
Osama Mersal
1) I've enabled the private reply for you.
2) Please let me know the steps to reproduce the issue.
Osama
April 26, 2024 at 12:50 pm #15570703
Osama Mersal
Thanks for the access details. I tried to deactivate the plugins to check for a plugin conflict, but I got a fatal error caused by your theme. Please deactivate your theme using FTP access.
Osama
April 26, 2024 at 7:45 pm #15571982
zachariasD
Ill just restore the backup from the live site, I think you cant really deactivate the plugins since it is a custom theme.
You could possibly change theme in the staging before deactivating. But how will you find out if it is double posting if you cant see it in the theme?
April 26, 2024 at 9:24 pm #15572168
zachariasD
Did the backup, please look at another way to find what is wrong instead of deactivating plugins.
Is this the first time someone has this issue? 🙂
April 27, 2024 at 1:01 pm #15572892
Osama Mersal
1) You use a custom theme, which could be part of the issue because the issue won't happen using a standard WordPress theme or a page builder.
2) I created a new sandbox site with ACF installed and your field groups and post types imported. Please log in to this sandbox site and install your theme. (hidden link)
After that, please create a test post and translate it to replicate the issue.
Osama
April 29, 2024 at 7:56 am #15575359
zachariasD
Hello again,
Sorry for the slow replies. I've done as requested in the sandbox 🙂
April 29, 2024 at 8:17 am #15575380
Osama Mersal
Thanks for replicating the issue. Please try replacing (get_posts) with (wp_query) in your front-end template and check if that fixes the issue.
Osama
April 29, 2024 at 8:54 am #15575683
zachariasD
I dont know how to do that 🙂
Where do I start?
