You are trying to translate variable products using WPML, and although the translations are marked as completed, the variations are not displaying correctly on the English version of the product page. Specifically, when selecting options like 'Choose Color', nothing happens, whereas the Spanish version displays variations correctly.
If you're experiencing this issue, we recommend you try the following steps:
1. Navigate to WooCommerce > WooCommerce Multilingual > Status > Troubleshooting.
2. Select "Sync products variations" and click on Start.
3. Edit the product in the original Spanish language, make a small change to the description, and then update the translation product.
IMPORTANT: Please backup your database and website before proceeding.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Additionally, you can open a new support ticket for further assistance at our support forum.
Last updated by 2 months, 3 weeks ago.
Assisted by: Long Nguyen.
