This topic contains 1 replies, has 1 voice.
Last updated by Bruno Kos 9 months, 3 weeks ago.
| Author | Posts |
| May 21, 2025 at 11:06 am | |
burakC-11 |
| May 21, 2025 at 12:39 pm #17057189 | |
Bruno Kos WPML Supporter since 12/2018
Languages: English (English ) German (Deutsch ) French (Français ) Timezone: Europe/Zagreb (GMT+01:00) |
While working with the XML configuration described on https://wpml.org/documentation/support/multilingual-tools/registering-custom-elementor-widgets-for-translation/#generating-xml-code-with-the-wpml-config-generator, I cleaned up the original configuration by removing fields that should not be translatable (such as layout, margin, or boolean fields) and kept only content-related fields (text, headings, URLs, etc.) <wpml-config>
<elementor-widgets>
<widget name="wdt-advanced-carousel">
<fields>
<field>item_contents</field>
</fields>
<fields-in-item items_of="item_contents">
<field>item_title</field>
<field>item_sub_title</field>
<field>item_description</field>
<field>item_link>url</field>
<field>item_button_text</field>
</fields-in-item>
</widget>
<widget name="wdt-advanced-heading">
<fields>
<field>title</field>
<field>subtitle</field>
<field>content</field>
</fields>
</widget>
<widget name="wdt-heading">
<fields>
</fields>
<fields-in-item items_of="header_positions">
<field>element_value</field>
<field>_id</field>
</fields-in-item>
</widget>
<widget name="wdt-button">
<fields>
<field>text</field>
<field>subtext</field>
</fields>
</widget>
<widget name="wdt-text-image">
<fields>
<field>features_content</field>
</fields>
<fields-in-item items_of="features_content">
<field>list_title</field>
</fields-in-item>
</widget>
<widget name="wdt-counter">
<fields>
</fields>
</fields-in-item>
</widget>
<widget name="wdt-interactive-showcase">
<fields>
</fields>
</fields-in-item>
</widget>
<widget name="wdt-mailchimp">
<fields>
<field>name_label</field>
<field>email_label</field>
<field>button_type</field>
<field>button_label</field>
</fields>
</widget>
</elementor-widgets>
</wpml-config>
Unfortunately, I was unable to save this XML directly via WPML’s Custom XML configuration page (/admin.php?page=tm%2Fmenu%2Fsettings\&sm=custom-xml-config). This seems to be caused by the REST API not functioning properly on your site. When trying to update content to test this XML, I encountered the following error: This is likely connected to the same REST API issue, which also prevents WPML from properly recognizing translations. To isolate the cause of the issue, could you please try the following? 1. Deactivate all non-WPML plugins, then try saving this page: 2. Temporarily switch to a default WordPress theme such as Twenty Twenty, and then try saving again. Also, when inspecting the browser console (in Chrome), I noticed some JavaScript errors that may be relevant. Since saving via the WPML settings panel failed, I’ve temporarily added the cleaned XML directly to the theme’s wpml-config.xml file: Let me know once you've tried the steps above. |
