The client is experiencing an issue with the Translation Management dashboard showing "2 translations waiting for review" even though there are none when checked.
First, we recommend backing up the database before making any changes. If the client is comfortable with database operations, we suggest running the following SQL query to resolve the issue:
UPDATE `wp_icl_translation_status` SET `review_status` = NULL WHERE `review_status` LIKE ''
If the client is not familiar with database operations, we can install the PHPmyadmin plugin to assist with the process. Alternatively, the client can manually check the
table for the
review_status
column and set it to "ACCEPTED" to clear the stuck queue. If these solutions do not resolve the issue, we are ready to provide further assistance and may involve our 2nd Tier Support.
If this solution doesn't look relevant, please open a new support ticket.
Last updated by Kor 1 year, 7 months ago.
December 4, 2023 at 6:01 pm
tannerT
Hey there, there seems to be a bug internally. On Translation Management I always see "
2 translations waiting for review", when I click on it there are none
December 4, 2023 at 7:05 pm
December 4, 2023 at 7:15 pm #14991003
WPML Supporter since 08/2022
Thanks for your patience.
I've checked and I think the plugin deactivation broke some languages. Could you please restore the site from your backup?
December 4, 2023 at 8:32 pm #14991367
tannerT
Hi Kor, deactivating the plugin and reactiving the plugin would definitely not break translations. I noticed you activated the Child Theme and restored the original Them
December 4, 2023 at 8:37 pm #14991371
Thanks for your reply.
Yes, the site broke when I deactivated the plugins and when I checked the debug logs, it's saying that the theme is causing issues. So, I've switched themes to fix the site. Could you restore the site from the backup so that I can continue escalating this to our 2nd Tier Support for further assistance?
[04-Dec-2023 18:53:08 UTC] PHP Fatal error:  Uncaught Error: Call to undefined function is_checkout() in /home/dev2ellasbubbles/public_html/wp-content/themes/flatsome/functions.php:793
Stack trace:
#0 /home/dev2ellasbubbles/public_html/wp-settings.php(611): include()
#1 /home/dev2ellasbubbles/public_html/wp-config.php(71): require_once('/home/dev2ellas...')
#2 /home/dev2ellasbubbles/public_html/wp-load.php(50): require_once('/home/dev2ellas...')
#3 /home/dev2ellasbubbles/public_html/wp-blog-header.php(13): require_once('/home/dev2ellas...')
#4 /home/dev2ellasbubbles/public_html/index.php(17): require('/home/dev2ellas...')
#5 {main}
  thrown in /home/dev2ellasbubbles/public_html/wp-content/themes/flatsome/functions.php on line 793
December 4, 2023 at 9:09 pm #14991669
tannerT
We are not able to restore the complete site from a the backup due to much implementation today. This will NOT be a possibility
Please take necessary steps to resolve the issue as intended vs. "restore from backup".
You still have complete admin access. Thank you,
December 5, 2023 at 9:56 am #14995077
I'm sorry to hear that you cannot restore from a backup. I will check and see if there is anything I can do from my end to fix the "broken language" and "Translation waiting for review" issues.
December 5, 2023 at 2:38 pm #14999547
tannerT
Waiting for update, of course we need to get this resolved. We started with a pesky translation notice, and now have no languages. Please escalate to corresponding departments or higher tiers to get this resolved immediately.
Like asking for a tire change and the company breaks your engine.
December 5, 2023 at 2:43 pm #14999629
I've rechecked and it looks like you've fixed the languages. I will proceed with escalating to our 2nd Tier Support to check on the "Translation waiting for review" issue.
December 5, 2023 at 2:44 pm #14999663
tannerT
I really appreciate it Kor!
December 5, 2023 at 2:52 pm #14999767
I've just escalated this to our 2nd Tier Support and I will come back to you once I have feedback.
December 5, 2023 at 3:17 pm #15000085
tannerT
Thank you, I am on standby
December 5, 2023 at 3:48 pm #15000475
I appreciate your patience.
I have some feedback, and I kindly request access to the server database to execute the following SQL query. However, before proceeding, please ensure that a full backup is performed.
If you are unsure about the process, I would also like to request permission to install the PHPmyadmin plugin, which will allow me to run the following SQL query:
December 5, 2023 at 5:31 pm #15001649
tannerT
See this image log here:
- Query Ran, 0 rows affected
- 2 Translations are still pending review
- Cannot be found at all
December 5, 2023 at 5:34 pm #15001653
Could you try checking the icl_translation_status table for the review_status column? Then manually set it to "ACCEPTED" and clear it from the stuck queue. Let me know if this method works. If not, I will ask for another feedback from our 2nd Tier Support.
