The client is experiencing an issue with the Translation Management dashboard showing "2 translations waiting for review" even though there are none when checked.
First, we recommend backing up the database before making any changes. If the client is comfortable with database operations, we suggest running the following SQL query to resolve the issue:
UPDATE `wp_icl_translation_status` SET `review_status` = NULL WHERE `review_status` LIKE ''
If the client is not familiar with database operations, we can install the PHPmyadmin plugin to assist with the process. Alternatively, the client can manually check the
table for the
review_status
column and set it to "ACCEPTED" to clear the stuck queue. If these solutions do not resolve the issue, we are ready to provide further assistance and may involve our 2nd Tier Support.
If this solution doesn't look relevant, please open a new support ticket.
Last updated by Kor 1 year, 6 months ago.
December 5, 2023 at 5:43 pm #15001687
tannerT
Here is the Query that will display what is needed:
SELECT * FROM `eb21icl_translation_status` WHERE review_status = 'NEEDS_REVIEW';
Here is the SQL Download for these 2 rows for further inspection of your dev team (please mark this as private) or remove download link from public: hidden link
