**Problem:**
The user (cristianS-23) reported that WPML displayed a notification indicating "90 translations waiting for review," but no translations were found in the queue under Posts, Pages, Products, or Knowledge Base sections. The user wanted to resolve this issue and ensure it does not recur.
**Solution:**
1. **Investigation:**
- Confirmed no translations were marked as "waiting for review" in the interface.
- Identified that the issue likely stemmed from incorrect entries in the `icl_translation_status` database table.
2. **Fix:**
- Suggested editing the database to update the `review_status` column in the `icl_translation_status` table to `'ACCEPTED'`.
- Clarified that this might fix the immediate issue but noted the root cause could be related to plugin or theme conflicts.
3. **Implementation:**
- User manually applied the suggested database change, which resolved the issue.
4. **Preventive Action:**
- Advised disabling the review feature if not required to prevent similar issues.
- Provided steps to disable the feature:
- Navigate to **WPML > Settings**.
- Under **Automatic translation**, select **"Publish right away without reviewing"** and save the settings.
**Outcome:**
The issue was resolved, and the user chose to mark translations as accepted before disabling the review feature. Additional support was offered but not required.
Last updated by cristianS-23 1 year, 5 months ago.
November 11, 2024 at 3:08 pm
cristianS-23
I am trying to accept translations awaiting to be reviewed. The issue can be seen at hidden link.
I expected to see translations to review, but instead, I got no translations to review.
Why are translations awaiting review not shown?
How can I access translations that need to be reviewed?
