This topic contains 28 replies, has 1 voice.
Last updated by Kor 9 months, 1 week ago.
May 28, 2025 at 9:11 pm #17085477
chrisL-17
I am trying to set up a directory of consultants that can be filtered by their area of expertise. This metadata is configured as a user field in Ultimate Memberships Pro. I have translated the terms using string translation, but the French terms do not appear on the directory page. The issue can be seen here: hidden link
The French terms do not appear in the directory. Instead, only untranslated English terms appear.
Why are the translated French terms not appearing in the directory?
How can I ensure that the translated terms appear correctly on the directory page?
May 28, 2025 at 9:25 pm #17085529
Please confirm if the terms have been translated at WPML > Taxonomy Translation.
https://wpml.org/documentation/getting-started-guide/translating-post-categories-and-custom-taxonomies/
Also, as I suppose the Consultants are a custom post type, make sure that they are all translated.
If this will not solve the issue, please let us know.
May 28, 2025 at 9:35 pm #17085533
chrisL-17
The site uses Ultimate Memberships Pro (hidden link) to track its members as well as display them in its member directory, which is the page that I've got the problem with.
So member records are not custom post types. And the custom user fields that UMPro allows me to create are not taxonomy.
The values of the user fields are available only to string translation in a domain called admin_texts_ihc_user_fields …that I can find, anyway.
May 29, 2025 at 7:37 am #17086504
Thanks for your reply.
I can see two terms showing up on the French Directory. I need to check the backend to understand the setup. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
June 2, 2025 at 4:57 pm #17098890
Thanks for your reply. I've reviewed the setup, and it appears to be quite complex. The guide here — hidden link — doesn’t provide details on how filters are translated.
To proceed, I’ve set up a sandbox site for testing: hidden link . Please install the necessary plugins, add a few members, and try to reproduce the filter issue on a test page.
If you're able to replicate the problem, I’ll escalate this to our 2nd Tier Support for further investigation.
June 5, 2025 at 9:58 am #17109430
chrisL-17
I'm trying to get the licensing sorted with Ultimate Memberships Pro so that I can install the full version on the development site you created.
My dev site license is registered to another domain.
June 5, 2025 at 2:43 pm #17110757
Ok, let me know how it goes.
June 12, 2025 at 3:44 am #17128267
chrisL-17
Envato won’t let me transfer the licence to this different temporary domain. If I can set up a permanent dev server, can we do the test there instead? The client has very little money and will not want to keep buying licenses.
June 12, 2025 at 9:16 am #17129163
Thanks for your reply. Yes, we can try this.
June 13, 2025 at 4:25 pm #17134228
Thanks for your reply. I can see the issue here hidden link .
I want to escalate this further to our 2nd Tier Support. I kindly ask for a snapshot of the staging site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
June 16, 2025 at 5:35 pm #17140067
Thanks for your patience. I've imported your Website into my local dev site and I will check and come back to you as quickly as possible.
June 18, 2025 at 6:49 am #17144701
Thanks for your patience. I will escalate this to our 2nd Tier Support for further assistance. I will come back to you once I've feedback.
July 14, 2025 at 7:19 pm #17235446
chrisL-17
Can you tell me anything about when/if this will be fixed or where you're at in the investigation/fix process?
My client is unable to do outreach to potential new members in french because their site's french member directory does not work.
cmkl
July 15, 2025 at 6:57 am #17236220
Thanks for your patience. I'm checking the status with the 2nd Tier Support and will come back to you as quickly as possible.
July 17, 2025 at 3:40 pm #17247043
Thanks for your patience. I have a feedback and this is what our 2nd Tier Support shared.
We are contacting the authors to cover all the missing parts; in the meantime, here is the workaround :
Workaround
1- Go to WPML > String Translation
2- Filter by "translation complete", search for field name "[ihc_user_fields]", this will list all the strings that the user already translated as part of the filter.
3- Select all of them and delete them, these strings are values used in the code and should not be translated
4- Open \wp-content\plugins\indeed-membership-pro\public\views\listing_users-filter.php
5- Search for line 167 under the case 'checkbox'
6- Replace
<?php
				foreach ($field['values'] as $v){
					if (is_array($get_value)){
						$checked = (in_array($v, $get_value)) ? 'checked' : '';
					} else {
						$checked = ($v==$get_value) ? 'checked' : '';
						<div class="iump-form-checkbox">
							<input type="checkbox" name="<?php echo esc_attr($field['name']);?>[]" value="<?php echo esc_attr(ihc_correct_text($v));?>" <?php echo esc_attr($checked);?> />
							<?php echo esc_html(ihc_correct_text($v));?>
						</div>
					<?php
With
<?php
					} else {
								// WPML: Separate value and label
								$wpml_original_value = ihc_correct_text($v);
								$wpml_string_name = 'checkbox_option_' . $field['name'];
								do_action( 'wpml_register_single_string', 'ihc', $wpml_string_name . '_' . sanitize_title($v), $wpml_original_value );
								$wpml_translated_label = apply_filters( 'wpml_translate_single_string', $wpml_original_value, 'ihc', $wpml_string_name . '_' . sanitize_title($v) );
								<?php echo esc_html($wpml_translated_label); ?>
							</div>
					<?php
7- Visit the Directory page in the front end, so WPML can load the new strings
8- Go back to WPML > String Translation, you will see the string loaded under a new domain "ihc", only translate those strings; its names should be formated as "checkbox_option_name"
The topic ‘[Closed] Ultimate memberships pro custom field strings translated but not appearing on directory page’ is closed to new replies.
