Last updated by julien-antoineB-2 1 year ago.
Assisted by: Noman.
September 30, 2024 at 1:42 pm #16236512
julien-antoineB-2
We are trying to edit the translation of products' URLs but it does not seem to show in the Advanced Translation Editor. In 'Settings > Translated documents settings', the option was set from 'auto-generated' to 'translate' (from the 1st option to the 2nd one) as an attempt to solve that issue, but it did not work. We need to be able to change the products URL, but would like to keep translating using the advanced editor if possible.
Unable to edit product URL using Advanced Translation Editor
How can we edit the translation of products' URLs using the Advanced Translation Editor?
Is there a specific setting in WPML that we need to adjust to enable URL translation in the Advanced Translation Editor?
