 Christopher Amirian
WPML Supporter since 07/2020
Languages:
English (English )
Timezone:
Asia/Yerevan (GMT+04:00)
I have this message:
I think it is better to use updraft or provide a copy of the database+plugins+theme, this new package it's even heavier, 2.5G.
Is it possible to provide us with the Updraft backup?
 Christopher Amirian
Languages:
English (English )
Timezone:
Unfortunately, the Updraft file is just a list of plugins and it is not possible to use it to create the installation on our side.
I want to do one more try to copy the website to our server via the Cloudways plugin.
I tried to login to:
But unfortunately, that is leading to a 404 page.
Am I missing something? Is there other URL I should use to access the dashboard?
 justinK-16
Hi Christopher
Try it now the WP login URL was changed when I last pushed/cloned the live site a few days ago.
Thank you
 Christopher Amirian
Languages:
English (English )
Timezone:
Thank you very much. Would you please also add the Support user? As it seems to be not available.
Or if you have new login information you can share by setting the next reply as private.
 Christopher Amirian
Languages:
English (English )
Timezone:
Thank you, I managed to move the website to the Cloudways server. I informed the compatibility team.
Will get back to you if I have more questions.
 Christopher Amirian
Languages:
English (English )
Timezone:
The compatibility team gave a workaround as follows:
- Go to WPML > Settings and temporary switch to the Classical Editor.
- Finish the problematic translations.
- Go back to WPML > Settings and set back to ATE.
- Finish the post translation.
 justinK-16
Hi Christopher
This has worked - even when switching back to the ATE it does not get overwritten. So all good for now.
Could you please advise/ask the 2nd Tier as to which is the correct code to leave in our functions.php
On the 9th July, you asked me to replace a line with this:
$translated_id = apply_filters('wpml_object_id', $id, $post_type, false);
It used to be:
$translated_id = apply_filters('wpml_object_id', $id, $post_type, true);
After making the change - nothing seems to change/wor or appear differently - so could you please advise which is the best/correct code?
Than you for your help.
 Christopher Amirian
Languages:
English (English )
Timezone:
Please keep the latest version of the code that you have now.
 justinK-16
Great thank you - and thanks again for all your help with this 🙂
