WPML Causing Backend Slowness and Duplicated Queries
We are aware of this issue and our developers are currently working on a fix. Meanwhile, we have an errata page that addresses this problem. We recommend you try the workaround suggested on the errata page after performing a full site backup. You can find more details and the workaround here:
Please try this solution and let us know your feedback.
Keep in mind that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket with us.
Last updated by Bigul 1 year, 9 months ago.
Assisted by: Bigul.
March 7, 2024 at 3:57 pm #15385611
thomasB-41
Our whole system is buggy, But the main issue, I think is that "Updating affected posts for changes in translatable fields" never progresses (see image). This seems to be affecting the posts that use those fields as they never resolve in the admin, even after being marked as 100% complete.
March 7, 2024 at 8:32 pm #15386741
Bigul
Our developers are currently working on this. But we have already created an errata related to this issue. Please check the following URL for more details.
https://wpml.org/errata/wpml-causing-backend-slowness-and-duplicated-queries/
Please try the workaround suggested there after a full site backup{mandatory} and let us know your feedback.
Bigul
March 8, 2024 at 1:54 pm #15389662
Bigul
Thank you for the feedback. As per the initial looks, it is not directly related to this issue. So I have opened a new ticket for the Translation never gets to "Completed" issue. As per our support policies, we can only handle one issue per ticket. It will help us to serve you better and we can avoid discussing multiple problems in one ticket. I will get back to you soon on the latest ticket. Please wait. Thank you for your understanding.
Bigul
March 11, 2024 at 2:57 pm #15396191
thomasB-41
Reassigning the translation job helped. I see this is public do you think you could hide it?
March 11, 2024 at 3:55 pm #15396435
Bigul
Thank you for the updates. I have removed the screenshots you have shared. Hope it will be okay. There are limitations to making a whole ticket as private.
Bigul
