Last updated by Long Nguyen 7 months ago.
Assisted by: Long Nguyen.
November 14, 2024 at 2:04 pm #16403044
piaP-6
I am trying to display the title of upsell products correctly on my Danish site.
The title of the upsell products is appearing in German on the Danish product.
How can I change the language of the upsell product titles to Danish?
November 18, 2024 at 7:05 am #16412976
Long Nguyen
WPML Supporter since 02/2022
Hi Peter,
Thank you for contacting WPML support, I’m happy to help you with this issue.
I can see the product title "Blockkerze LILA mit Rillen, 6,8 x 10 cm" is in German language and displayed in the Upsell products section in Danish language.
I suggest you follow some steps below and see if it helps:
- Edit the product in the original language
- Make a small change to the product description > Save
- Update the translation product
- Clear the cache (Litespeed)
November 18, 2024 at 8:04 am #16413191
piaP-6
Hi Long
Unfortunately, that did not help.
In the backend on the original product, I see that the German products is added. How I that even possible?
November 18, 2024 at 8:34 am #16413308
Long Nguyen
I would like to request temporary access (wp-admin and FTP) to your site so I can take a better look at the issue. It would be better to have a testing site where the issue is replicated. Your next reply is set to private to share the info.
November 18, 2024 at 8:45 am #16413383
piaP-6
I am not able to offer that. The site has 200 orders per day and we do not have a staging site because the site is 30 GB +
November 18, 2024 at 9:48 am #16413889
Long Nguyen
Can you remove the related product, re-select it and update the product in Danish language?
Also, please go to WPML > Support > Troubleshooting > Click on some buttons below and check if the issue is resolved.
- [Products] Synchronize posts taxonomies
- Clear the cache in WPML
- Set language information
- Fix terms count
- Fix post type assignment for translations
November 20, 2024 at 4:59 pm #16425823
piaP-6
Unfortunately, that did not help. I have run the troubleshooting options in WCML as well.
I have looked into the postmeta table of the database and the post ID's in the _upsell_ids field is simply referring to the German translation instead of the Danish. That's weird..
November 21, 2024 at 1:22 am #16426977
Long Nguyen
Did you edit the product in Danish language, re-select the upsell products and re-update the product? If it still doesn't work, what happens if you manually replace the product ID in the upsell post meta value with the product ID in the original language?
November 22, 2024 at 12:08 pm #16433696
piaP-6
Hi Long,
That will help indeed. However, that does not clear out the reason for the issue. Neither if the issue is occurring on others of the 3K+ products.
Best Regards,
Peter
November 25, 2024 at 1:24 am #16437706
Long Nguyen
I understand your situation, however, I cannot replicate the issue on a clean installation of WordPress with some new products. Does this happen when you create new products?
If it is possible, I recommend you copy your site to a staging site and share the credentials or at least, share the database archive so I can investigate the issue on the site. Your next reply is set to private to share the info.
December 5, 2024 at 9:54 am #16480712
piaP-6
Hi Long,
I think I have narrowed down the issue. I think it is a compatibility issue with WP All Import.
I tried to import the csv below as a test. The ID's in first columns are only Norwegian ID's. The 4 products are updated with the SKU's in the second columns, and they are correctly translated into the Norwegian version of that product. However, the Danish translations get the exact same ID's set in the database even though they should be touched because they are not in the file and if there are touched, they should be set with the Danish translation of the upsell product - not the Norwegian one.
I think I can replicate the issue in a sandbox if you can offer such an enviroment.
id;upsell_sku
127055;21001494,24001741,24001652,23001867,24001742,23001865
124767;21001823,21001821
127058;23001941,21001858,24001751,24001750,24001647,24001741,21001850
126655;87419D
December 6, 2024 at 1:23 am #16484283
Long Nguyen
You can access the sandbox site with the following URL hidden link
I've installed all necessary plugins WP All Import Pro, WPAI WooCommerce Import, WPML plugins ... that you need to import products.
Please try to replicate the issue with a few products so we can narrow down the issue. Then share with me steps to replicate it (or a screen record of steps you do) and the file that you use to import.
The topic ‘[Closed] Upsell title products’ is closed to new replies.
