I am trying to: Since the last update of WordPress, WPML stopped showing the English translation of this page (and the same for blumojacar.com). It has the code added to a hook via Astra Advanced Hook. It shows different ACF fields depending on the language with those if statements:
<section>
<?php
// check for rows (parent repeater)
if( have_rows('carta') ): ?>
<div id="carta">
<?php
// loop through rows (parent repeater)
while( have_rows('carta') ): the_row(); ?>
<div class="bloque-seccion">
<h3 class="nombre-seccion">
<?php
if (ICL_LANGUAGE_CODE == "en") {
the_sub_field('section');;
} else {
the_sub_field('seccion');;
</h3>
<?php
// check for rows (sub repeater)
if( have_rows('platos') ): ?>
<ul class="platos-seccion">
<?php
// loop through rows (sub repeater)
while( have_rows('platos') ): the_row();
// display each item as a list - with a class of completed ( if completed )
<li><span class="nombre-plato"> <?php
the_sub_field('name');;
} else {
the_sub_field('nombre');;
?></span><span class="precio-plato"> <?php the_sub_field('precio'); echo '€';?></span></li>
<?php endwhile; ?>
</ul>
<?php endif; //if( get_sub_field('items') ): ?>
</div>
<?php endwhile; // while( has_sub_field('carta') ): ?>
</div>
<?php endif; // if( get_field('carta') ): ?>
<div class="contenedor-alergenos">
<?php if (ICL_LANGUAGE_CODE == "en"): ?>
<a class="link-alergenos" href="<em><u>hidden link</u></em>">Allergen information</a>
<?php else: ?>
<a class="link-alergenos" href="<em><u>hidden link</u></em>">Información sobre alérgenos</a>
<?php endif ?>
</div>
</section>
Link to a page where the issue can be seen: hidden link hidden link hidden link hidden link
I expected to see: The same it has been working for years, the menu with the English fields.
I've been researching by my side and it ended up being a problem of the Astra advanced hook not hooking the info correctly, nothing to do with WPML. I made it in php straight in the child them and worked nicely.
Thanks a lot anyway for the help.
Regards
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
