Last updated by Bruno Kos 8 months, 2 weeks ago.
Assisted by: Bruno Kos.
November 21, 2024 at 6:52 am
adrianD-20
I am experiencing an issue with the WPML plugin on my site hidden link. The primary language SK is working fine, but there is a problem with the EN language. I have followed the steps in this topic: https://wpml.org/forums/topic/wpml-seems-to-cause-an-internal-server-error-php-warning-preg_replace-comp/. The error message I encountered is: Warning: preg_replace(): Compilation failed: quantifier does not follow a repeatable item at offset 2 in /data/4/f/4f0c7f68-8b77-445b-932d-9c19c624d4ee/taxi-bratislava-city.sk/web/wp-content/plugins/sitepress-multilingual-cms/classes/utilities/class-wpml-slash-management.php on line 118.
Warning: preg_replace(): Compilation failed: quantifier does not follow a repeatable item at offset 2 in the WPML plugin.
November 21, 2024 at 7:34 am
November 21, 2024 at 7:35 am #16427597
Bruno Kos
Let me know if PHP 8.1 / 8.2 resolves this issue.
November 21, 2024 at 7:55 am #16427705
adrianD-20
I tried both versions - the problem was not solved. Currently I have kept version 8.1
November 22, 2024 at 6:01 am #16431867
Bruno Kos
To troubleshoot this problem, I'll install the Duplicator plugin and generate packages for further debugging purposes. I'll ensure to exclude all media files to maintain a minimal package size. You can find more information about the process here: [link](https://wpml.org/faq/provide-supporters-copy-site/). Please confirm if this approach is acceptable to you.
The topic ‘[Closed] Warning: preg_replace(): Compilation failed: quantifier does not follow a repeatable item at offset …’ is closed to new replies.
