In Classic Editor, when entering a tag name, the AJAX request (ajax-tag-search) does not return some tags in Ukrainian, even though they exist in the database and are correctly translated in WPML. This issue does not occur in Gutenberg.
If you're experiencing this issue, we recommend you go to WPML -> Languages and check the box for
Adjust IDs for multilingual functionality
. This adjustment should resolve the issue by ensuring that the AJAX requests in Classic Editor correctly recognize the language settings.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
This topic contains 38 replies, has 2 voices.
Last updated by Lauren 1 year, 2 months ago.
Assisted by: Lauren.
February 11, 2025 at 7:58 pm #16693438
tarasL
I didn't have enough room to back up. The operation was aborted.
February 11, 2025 at 8:06 pm #16693529
Lauren
If you are unable to use the cloudways site that I set up, please use a plugin such as WP Staging or ask your hosting provider to set up a staging site where we can further troubleshoot.
February 11, 2025 at 8:24 pm #16693593
tarasL
ok
February 12, 2025 at 3:14 pm #16697520
Lauren
I have marked the next reply as private so that you can securely share credentials to your staging site. Thanks!
February 13, 2025 at 10:57 am #16701266
tarasL
Hi. I have made a copy of the site. You can log in with the same details as in the post dated FEBRUARY 4, 2025 AT 4:55 PM
February 13, 2025 at 6:18 pm #16704105
Lauren
Great, can you send me the link to the staging site? I have the credentials in your previous post but not the URL to login. I've marked the next reply as private so that can share the links in the secure fields.
February 13, 2025 at 6:54 pm #16704197
tarasL
you didn't enable private mode. so here's the link above
February 14, 2025 at 6:17 pm #16707791
tarasL
Did you get access? Is everything okay?
February 14, 2025 at 6:32 pm #16707821
Lauren
When I used the link you sent yesterday, it redirected me to the regular site, not a staging site. I checked again today and now when I try the link it get a message that it has been forgotten. Please share credentials to the staging site in your next reply and use the private fields ot send the credentials not the general response field.
February 14, 2025 at 6:43 pm #16707851
Lauren
This is the link to your STAGING site? Because it is the same link that you used in the original chat that was opened. So before I begin setting the site to minimal and disablign plugins and theme, please confirm that this is the correct link to run these tests: hidden link (this link will remain hidden to anyone not logged in to this ticket).
February 14, 2025 at 6:51 pm #16707854
tarasL
Yeah, it's a test site. You can do whatever you want with it)))
February 18, 2025 at 4:50 pm #16720310
Lauren
I deactivated all non WPML plugins and ran through the clean up steps in the troubleshooting section. I then created a test post named WPML test. Now, when I type Трамп in the tags, I can see more results. Can you confirm that it is working for you as well?
If so, please start to enable the plugins one a time and check to see if the issue returns. If it does, let me know which plugin is conflicting.
February 18, 2025 at 8:19 pm #16720858
tarasL
This is because you enter words in the news in Russian. But you should be in Ukrainian.
You're very careless 🤦‍♂️
February 18, 2025 at 8:53 pm #16721004
Lauren
I double checked earlier in both languages multiple times, but now it's showing different again. And I am also seeing that some of the terms (for example, "Tags" was previously showing as translated and now it's in English). Did you happen to enable any plugins in between my last test and now?
I also noticed that if you click "Choose from the most used tags", I am seeing the tag "Дональд Трамп" - are you seeing that there in both languages? I've confirmed I'm on the Ukrainian post and this is the link to the post I am testing on: hidden link
February 18, 2025 at 8:57 pm #16721010
tarasL
I didn't do anything, I didn't touch any plugins. I created a news item and immediately checked the tag.
I see Donald Trump in the tags I use most often.
