In Classic Editor, when entering a tag name, the AJAX request (ajax-tag-search) does not return some tags in Ukrainian, even though they exist in the database and are correctly translated in WPML. This issue does not occur in Gutenberg.
If you're experiencing this issue, we recommend you go to WPML -> Languages and check the box for
Adjust IDs for multilingual functionality
. This adjustment should resolve the issue by ensuring that the AJAX requests in Classic Editor correctly recognize the language settings.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
This topic contains 38 replies, has 2 voices.
Last updated by Lauren 1 year, 2 months ago.
Assisted by: Lauren.
February 19, 2025 at 2:34 pm #16725280
Lauren
This ticket has been escalated to our 2nd tier support and I'll update here as soon as I have more information.
February 19, 2025 at 8:36 pm #16726739
Lauren
Our second tier support thinks something is cached improperly on your site - probably object cache on the server. Please try clearing all caches and transients as some of those are cached as well (browser cache, server cache, and any caching plugins you have used should be cleared). You may need to reqeust assistance from your hosting provider to confirm all are cleared. Please let me know if anything changes after all caches/transients have been cleared.
February 19, 2025 at 8:46 pm #16726764
tarasL
I'm going to disappoint you. We don't use object caches. Only wp-rocket (which you have disabled). And basic OPcahce caching is enabled. All of it
What's more - the site is on a new server. With absolutely clean settings.
February 20, 2025 at 8:30 am #16728060
tarasL
You're talking about caching. Explain why all labels are displayed in the gutenberg editor? They don't in the classic editor. I think you've forgotten the point I was trying to make.
I'll remind you that my request is already 20 days old, and we haven't moved forward.
February 20, 2025 at 7:59 pm #16731235
Lauren
I have not forgotten the issue at all. It shows correctly with gutenberg, also shows in commonly used tags. It showed for me in the tag search then disappeared, and showed in the link for our 2nd tier and then disappeared. That fact that it shows in some places but not others, and some times but not others, often means there is something related to caching which is why we asked to check. Our second tier is going to need a copy of the site for further testing. Cloudways failed, and Duplicator failed probably due to the large size of the site. I will try to make a copy using All in One Migration that I can forward to our developers for further troubleshooting.
February 20, 2025 at 9:32 pm #16731516
tarasL
thanks
February 21, 2025 at 9:44 pm #16735346
Lauren
Please go to WPML -> Langauges and check the box for "Adjust IDs for multilingual functionality". This seems to resolve the issue as far as I can tell, please confirm if it is working on your end as well.
February 21, 2025 at 9:52 pm #16735350
tarasL
Oh, great! It works.
Thank you so much!
February 24, 2025 at 6:15 pm #16742630
Lauren
You are welcome, I'm happy we were able to resolve this for you. Please don't hesitate to open up a new chat if you run into any further issues.
