You are experiencing a fatal error when trying to log in to the admin dashboard, specifically an error related to an unknown format specifier 't' in the WPML String Translation plugin.
We are aware of this issue. As a temporary solution, we recommend you refer to our errata page for details on how to address this problem: https://wpml.org/errata/flux-checkout-fatal-error-uncaught-valueerror-unknown-format-specifier-t/.
This issue is expected to be resolved in an upcoming release.
If this solution does not apply to your case, or if it seems outdated, please open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, you can contact us directly through our support forum at https://wpml.org/forums/forum/english-support/.
Last updated by Andrey 10 months ago.
Assisted by: Andrey.
April 10, 2025 at 3:30 pm #16919608
newsF
I am trying to log in to the admin dashboard but encounter a fatal error. The issue can be seen at the following link: hidden link
Fatal error: Uncaught ValueError: Unknown format specifier "t" in /var/www/html/wp-content/plugins/wpml-string-translation/classes/translations-file-scan/wpml-st-translations-file-registration.php:100
How can I resolve the fatal error when trying to access the admin dashboard?
April 10, 2025 at 5:46 pm #16920152
Andrey
WPML Supporter since 06/2013
Our development team is aware of this issue. As a temporary solution, please refer to the following link:
I hope this matter will be addressed in upcoming releases with any necessary improvements.
