Last updated by Bobby 1 year, 5 months ago.
Assisted by: Bobby.
January 16, 2024 at 11:29 am #15189531
support@onenonly.info
I am trying to use the Webstories plugin on my site. I have seen the links are not working
Use dev in both fields for authentication popup.
I expected to see: When clicking on the learn more button, it should take the user to the article
Instead, I got: Nothing happens
If I deactivate WPML sticky links, the links are working fine. I checked the database and found that WPML Sticky links save the URL as their page_id.
Can you please have a look?
January 16, 2024 at 7:38 pm #15191981
Bobby
WPML Supporter since 04/2015
Is this happening on both the default language and translations?
At the moment the plugin is not officially compatible with WPML, however, our team is actively working with their authors to make it officially compatible.
Is there a specific reason you need to use Sticky Links? Sticky Links will by default store the page ID number rather than the URL
"instead of storing the URL of that page (at the time the link was created), it stores the page number. This can never change, no matter what you do."
Documentation:
https://wpml.org/documentation/getting-started-guide/sticky-links/
January 18, 2024 at 12:04 pm #15199593
So if I want to interlink other language blog posts from some blog post, will WPML Sticky link plugin help?
What to do with the links that are created using WPML Sticky links?
Is there any way to revert?
January 18, 2024 at 7:09 pm #15201908
Bobby
With sticky links, we recommend using this code to prevent this.
https://wpml.org/documentation/getting-started-guide/sticky-links/#linking-to-pages-in-a-different-language
See an example here:
To revert links you would go to WPML Sticky Links and click on the revert button but do keep in mind that this would rever all links and not specific ones only.
The topic ‘[Closed] Webstories not working with WPML Sticky links’ is closed to new replies.
