Last updated by Kor 7 months, 1 week ago.
March 25, 2025 at 1:43 pm #16857991
vivekP
I am trying to clear the message 'This is only a copy - original site is still running' from my WordPress admin page. The issue can be seen at the following URL: hidden link.
I expected the message to be cleared out, but instead, I got an error: 'Error with copying translation information to new URL. WPML was unable to copy your site's translations, translation memory, and glossary to this new URL.'
How can I clear the message 'This is only a copy - original site is still running'?
What causes the error with copying translation information to a new URL?
March 27, 2025 at 2:03 am #16865958
WPML Supporter since 08/2022
Thanks for contacting us. I suspect some connection issues with the Website as explained here https://wpml.org/faq/wpml-plugin-cannot-connect-to-wpml-org/
If the issue continues, I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
March 30, 2025 at 7:06 pm #16876950
Thanks for your reply. I've corrected the configuration for you and that error message should be gone now.
However, I'm seeing this new error. Could you please make the folder writable on your server? You can reach out to your hosting provider if you're not sure what to do here.
WPML String Translation is attempting to write .mo files with translations to folder:
/files/languages . This folder appears to be not writable
March 31, 2025 at 1:26 pm #16879626
vivekP
Thank you for your help! We see the issue is resolved on that test environment. Can you please provide us details on what you changed so that we can make the same change on our primary dev server? That is where the issue first started, and this environment you corrected is one we stood up to give you access to - now we need to replicate the fix on our main dev server.
Thanks for your help!
March 31, 2025 at 2:47 pm #16879990
Thanks for your reply. This is what I've done.
1. For the first prompt, I've selected "This is only a copy - original site is still running"
2. Then, for the second prompt, I've clicked "mark it as a copy" as explained here https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/using-advanced-translation-editor-when-you-move-or-use-a-copy-of-your-site/
If you still need help, please share access to your production site and I will check this out for you.
The topic ‘[Closed] When I click on “This is only a copy – original site is still running”. I reappears again’ is closed to new replies.
